I know its been covered in more than several archived posts, but one question for anyone who has removed a 91's......do the 4 13mm mounting bolts also serve to mount the waterpump pulley??
Several threads have stated that the belt did not have to be removed which would lead me to believe the waterpump pulley has it's own separate set of bolts!
Any help would be most appreciated and {Lying mode activated} rewarded with cash{Lying mode deactived} confused
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Frisbee removal '91... (vette5)
:confused: ...and no I'm not lying
:cheers: It's the same, one set of bolts.
If you are quick and carefull you can remove the nuts and the frisbee without removing the belt, but it is better IMHO to remove the belt
Get several washers, per bolt to replace the thickness of the frisbee
You'll like the results of removal, engine spools up a bit faster
Thanks guys......guess I'll have some extra washers handy just in case....I've seen pics of the early Frisbees and the late ones and early ones looked a bunch thicker requiring washers.
No washer needed, you can use an oil filter wrench to hold the pulley while tightening.
.......Great idea.....gonna do it.
I used the washer to be sure that the nuts didn't get down to the bitter end of the boltsa and to be sure of correct pulley alignment.
.........I read about another member who had pulled his Frisbee without installing the washers....he was getting a whine after starting the car....he installed the washers and it went away....must of been the bolt tips hitting the water pump housing.....anyway....I'm gonna have a few washers on hand just in case......I think, from all I have read on the subject it is "Year Model Specific".
Mucho Gracias to everyones' input....gonna do it over the weekend
I will be performing this operation tonight, I'll see how she runs at about midnight. :yesnod:
.......Let me know how it goes "Mile High", OK......off the topic, but heard on the news tonite, we just sent a few Firefighters your way to help out.....hope all is well with your place :)
