FIC injectors installed....is this normal...
Old Jan 18, 2013 | 07:31 PM
im4darush's Avatar
im4darush
Default FIC injectors installed....is this normal...
got the injectors and installed in 30 mins. Car is a 92. Needless to say the car runs great with no more miss. One thing I noticed is a bit weird. First time I fired it, the idle was steady at 900 even when hot. After a bit of run time I let it sit and fired it again. This time it came down to 750 or so. Went for a drive and after 5 mins of driving it was back to 900. Let her sit for about 2 hours, fired it again and it settled at 750. Rock steady with no surging. But I do notice that as the car gets warmer and after it is driven, the idle does creep up. This sound normal? I will say that after reconnecting the battery I only drove it for 3 miles or so. I did let it idle for 15 mins as stated in the directions.
Old Jan 18, 2013 | 08:55 PM
l98tpi's Avatar
l98tpi
Max G’s
May just need to re tune for the new injectors. Even if you have the same lb/hr injectors, the flow may be slightly different. The problem may go away after a while or may need to be tuned out.
Old Jan 18, 2013 | 10:26 PM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Give Jon a call. He might be able to tell you what needs to be done.
His injectors are designed to be a complete "Plug & play" experience.
You might possibly have another issue with one of the many sensors on your LT1 engine.
Old Jan 18, 2013 | 11:11 PM
leesvet's Avatar
leesvet
Probably have an air leak in the plenum/runner assy gaskets. You say you did the work in 30 minutes? That's a bit too fast to be good, clean work. Even on a LT.
You have air leaks. You will also have fuel leaks from rail o-rings soon. You can get air leaks in the inj seats if the inj was not "set" properly and the new o-rings were not lubed with vasoline.
You also have to drive the car to establish a BLM that will help the ECM establish a pattern for the "tune" that is programmed. The BLM helps to anticipate so the ECM reacts faster instead of waiting...OBD-I ECMs of the 80s had as much power as a cheap calculator today. "pong" of the automotive electronics world...
Each time you d/c the battery you clear the BLM and the ECM has to re-establish a new set. Memories...
Old Jan 18, 2013 | 11:43 PM
aboatguy's Avatar
aboatguy
Sorry brother, but 30 minutes is about right on a LT1 fuel injector change, and thats if you are taking your time. LT1 doesn't have any gaskets involved in an injector change.
Concur with you on lubing the o rings will alleviate the possibility of tearing one on install. If the OP removed the battery during his install after some driving time the idle speed may even out. However, if it were mine I'd clean the TB and IAC ....
MIke
Old Jan 19, 2013 | 08:13 AM
im4darush's Avatar
im4darush
Injectors and rail were treated with lube and set correctly. There were no leaks. When first started it idles excellent at 700-750 so I am confident there are no vac leaks. It is after it is driven that the idle creeps up. And again, it was only driven a few miles and has about 30 mins idle time on it so it may still correct itself once the ECM gets more drive time.
Old Jan 19, 2013 | 08:18 AM
Gobygred's Avatar
Gobygred
Is it simply the controller learning the new parameters from the change?
Old Jan 19, 2013 | 12:00 PM
leesvet's Avatar
leesvet
I keep forgetting that LTs are 1 piece and not 3 piece like L98s.
If you're sure there are no o-ring air leaks or others then it has to be related to the ECM being cleared of memory.
There is a min time for the ECM to read and store the new BLM patterns for lack of a better term...its a matter of seeing a brief example of how the car is running and storing that data so the program can react faster in the future...a little like cookies on the computer. Erase them and the computer has to search to load a page the hard way...if cookies are present thats a short cut to the same end result.
I forget what the min time was...it wasn't much. Something like 30 sec above ?? mph steady. I dunno...its been a while. Maybe it was 8 secs over 30 mph?
Whatever,. it was pretty easy to do.
Old Jan 19, 2013 | 04:29 PM
Pingman326's Avatar
Pingman326
I just installed FIC injectors in my 93' and I didn't have that problem. I was very clean and careful with the whole process though and I also changed my fuel filter. (what a pain that was!)
Old Jan 19, 2013 | 05:33 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
I would think the iac might be sticky.. the iac is a controlled vac leak, make sure the throttle blade shaft is smooth and the throttle cable is free and not sticky. make sure none of the vac hoses are loosely fitted. Its air for sure..
Cole
Old Jan 19, 2013 | 08:00 PM
aboatguy's Avatar
aboatguy
Cole
....and is the reason I posted the following yesterday
"... However, if it were mine I'd clean the TB and IAC ...."
MIke
To FIC injectors installed....is this normal...
