Flushing brake fluid question?
Old Jan 19, 2013 | 02:45 PM
Mike96Coupe's Avatar
Mike96Coupe
Default Flushing brake fluid question?
Its been a couple years, should the ignition be on or off?
The last time I removed what I could with a turkey baster, started on the right rear, then left rear, right front, left front, until had clear fluid at all wheels.
Any other words of wisdom would be appreciated.
Old Jan 19, 2013 | 02:55 PM
Aardwolf's Avatar
Aardwolf
Key can be off, I haven't found wheel order to be important.
Old Jan 19, 2013 | 03:33 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Wheel order may be important given your year (presumed 96 based on ID) has an ASR/ABS unit which has valving which can be pushed out-of-position if bleeding in the wrong sequence.
Suggest following the wheel sequence in the FSM.
Also, don't forget to first bleed the ASR/ABS unit (compartment behind driver seat).
Old Jan 19, 2013 | 03:39 PM
John A. Marker's Avatar
John A. Marker
Key off.
Drain as much fluid from the reservoir as you can. Fill it with new fluid and start with the right rear wheel. I will slip a clear plastic hose onto the bleeder and put the hose into a glass jar. This way when I pump the brakes you can see the new clear fluid come out the hose into the jar. Don't let the fluid in the reservoir go empty. Have a friend constantly fill it as you pump the brakes.
Once you have clear fluid coming out the right rear, then close off the bleeder and go to the left rear. Repeat the above. Then move to the fight front and then the driver's front.
Since you have a 96, use DOT 4 fluid. There was a recent thread about break fluids....check it out.....
http://forums.corvetteforum.com/c4-g...ake-fluid.html
Old Jan 19, 2013 | 05:22 PM
pmihaltian's Avatar
pmihaltian
Slingshot
I have aways followed the order you identified without incident or problems. I couple of years ago I purchased a Motive brake bleeder which works like a charm. Check it out....
Old Jan 20, 2013 | 03:27 PM
Mike96Coupe
Mission accomplished. Thanks
Old Jan 20, 2013 | 04:42 PM
corvette-pilot's Avatar
corvette-pilot
And what gameplan did you go by?
Old Jan 21, 2013 | 07:45 AM
Mike96Coupe
Key off.
01-19-2013 03:33 PM
I used the same process a couple years ago. Pretty simple.
To Flushing brake fluid question?
