service engine soon light
Old Jun 12, 2002 | 10:59 PM
Ray Montgomery's Avatar
Ray Montgomery
Default service engine soon light
I just noticed tonight that my service engine light came on, just looking for suggestions on how you all might deal with it before taking it off to a service tech. would you disconnect battery positive cable first? I know that once i had this light come on and the dealership did the battery cable and charged me 55 dollars and said that it had to be reset and it has not been on since and that was over a yr ago and the car has been running great....Juat some input guys....thanks so much in advance .
Old Jun 12, 2002 | 11:36 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: service engine soon light (Ray Montgomery)
Ray, I would like to find out what code set before clearing it. Go to a good service station and talk nice to them and I bet they might hook it up to their scanner and tell you the code for free. I would be happy to hook my scanner up to it if you drive up here.
Old Jun 12, 2002 | 11:40 PM
ittlfly's Avatar
ittlfly
Just use the paper clip trick to read the codes. There are plenty of threads to give you the procedure. That will give you an idea of what's up for free! :yesnod:
Old Jun 12, 2002 | 11:48 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: service engine soon light (ittlfly)
Does the paper clip work on a '96? Isn't this about the time they switched to OBD II?
Old Jun 13, 2002 | 11:12 AM
ittlfly's Avatar
ittlfly
Default Re: service engine soon light (Bob86ZZ4)
Yes, I believe it will work fine on the OBDII...just bridge A to B , turn on ign. and watch for codes. Kragen sells the autoxray for $159. that will work on your car. It sure is a lot of help in getting to the problem.
Old Jun 13, 2002 | 11:39 AM
K87ZZ4's Avatar
K87ZZ4
Some auto parts stores have simple code readers that they will use to read the service codes... typically advertised as a free service.
Old Jun 13, 2002 | 12:18 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
You need a scanner for a 96 OBDII car.
Old Jun 13, 2002 | 01:11 PM
ittlfly's Avatar
ittlfly
Default Re: service engine soon light (PeteL)
Pete..I think autoxry makes a unit for the OBDII system....but I stand corrected on the price. It will work with the OBDI system also....the price is up around $300+ tho....
Old Jun 13, 2002 | 06:47 PM
VetBoy89's Avatar
VetBoy89
AutoZone does it for free, takes about 2 minutes to run the scan. :yesnod:
To service engine soon light
