LT1 HUB Install (automatic tranny)
My goal is to replace the Frt cover seals and the water pump gear. The Harmonic Balancer is removed. Now I'm at a point in which I'm planning to remove/install the HUB. I have the LT1 Hub/balancer puller tool and this is my first attempt on removing/installing the hub.
This 93LT1 is an automatic. My concern is how do I prevent the crankshaft from rotating when I install the hub?
If it was a manual transmission I"d put into gear. But since it's an automatic, would I have to access the fly wheel and bind it to prevent the crank shaft from moving? Is this procedure necessary when installing the hub?
I have the GM Service manual and no where in it does it have guidelines to prevent the crank shaft from rotating.
Thank you for your help.
Hank
You are going to also need a water pump install tool or something like this to install the new wp seal.
