guide plates?
Old Jun 12, 2002 | 11:58 PM
x_streme's Avatar
x_streme
Default guide plates?
Did the heads have guide plates on a '90? I pulled my heads off last weekend and they had them. They also had aligning rockers though. Just curious, but I didn't think any came like that from the factory.
Old Jun 13, 2002 | 01:09 AM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Cruise-In II Veteran
Currently Corvette-less
Default Re: guide plates? (x_streme)
My 92 LT1 has self aligning rockers and guide plates. According to Jeff Kopp, the plates were installed by te factory to assist in assembly. No big deal, run them both.
~ Purp
Old Jun 13, 2002 | 02:11 AM
GlockLT4's Avatar
GlockLT4
Default Re: guide plates? (PurpleC4)
Hmm.. i was under the impression that self aligning and guide plates together were a bad idea. (specifically with the 1.6 RR's in the LT4 and others)
Old Jun 13, 2002 | 03:28 AM
drive it's Avatar
drive it
Default Re: guide plates? (Glock'94)
Yea, same thoughts here....after helpin' on a friends 90 and getting a close look it seems the factory guide plates have a bigger gap than aftermarkets-so I guess that's why it's OK to run it that way???
Old Jun 13, 2002 | 06:55 AM
Half Fast's Avatar
Half Fast
~ Purp
:yesnod: You'll have to change the guide plates if using non-self aligning rockers.
[Modified by Half Fast, 5:56 AM 6/13/2002]
Old Jun 13, 2002 | 07:30 AM
DON M's Avatar
DON M
The factory installed these for assembly only. The are not hardened, have a wider slot and cannot be used for non-aligning rockers. It would be a bad idea to run hardened guideplates and self-aligning rockers.
To guide plates?
