Help Identify Connector!!
I'm trying to get it running and I found this connector under the dash that looks important but is not hooked up
someone else monkeyed with this car before me and I'm trying to get it running. Any help is appreciated!
I am trying to get a picture uploaded of the connector
<a href="http://s1219.photobucket.com/albums/dd424/arandompersons/Album%201/?action=view&current=20130122_165321 .jpg" target="_blank"><img src="http://i1219.photobucket.com/albums/dd424/arandompersons/Album%201/20130122_165321.jpg" border="0" alt="Uploaded from the Photobucket Android App"></a>
http://i270.photobucket.com/albums/j.../connector.jpg
There are tutorials in the help section below on how to post.. Looks like you are close.. Year might help also..
The OP it seems might have as much trouble with sorting the "phone or Android device" as he's likely going to have with his most recent Corvette purchase! Just sayin'
[ IMG ]http://www.somedomain.com/xxx.jpg[ /IMG ]
Another way to do it is click the "Go Advanced" button. Once there, click on the little icon that looks like a post card (remember those?). A dialog box will come up that you can type or paste the link into.
wvzr-1 what is the directional switch? I'm guessing turn signals correct?
I know I'm close to getting this on the road and am still researching before I bombard the forum with questions!
Tried looking in a manual a friend let me borrow but no luck there. If its not major I'm thinking of letting it be and trying to focus on getting it running first. Thought maybe it could be a very important connector stopping it from starting. At least I was able to solve a few problems with one of the machines haha
Good luck!
It's a heat sink with a transistor mounted on it and is bolted
to a bracket on the left side and the near the middle of the steering
column.
It controls the background lighting brightness (which depends on the position of the dimmer switch) for the following items when the headlight switch is in the Head or Park position.
PRND indicator for Auto trans, Radio and HVAC control heads,
LH, RH Power seat switches, Driver information
center and Selective ride control switch, Power
mirror switch, RH, LH Power window switch,
Lighted rear view mirror and LH, RH Door Courtesy
lamps.
column.
lamps.
