Smog pump removal
Old Jan 22, 2013 | 11:11 PM
kilich's Avatar
kilich
Default Smog pump removal
Has anyone just straight up removed the smog pump? if so what size belt did you by to bypass it? I dont wanna keep trying belts till i find the right one when i go to do it.
Old Jan 23, 2013 | 01:10 AM
gerardvg's Avatar
gerardvg
Hi with the air pump bypass pulley you get to use the same belt.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050F
Old Jan 23, 2013 | 02:36 AM
vetteoz's Avatar
vetteoz
Not without the pump eliminator pulley mentioned.
Check where the belt will run without the pulley in place
Old Jan 23, 2013 | 08:59 AM
Muffin's Avatar
Muffin
Old Jan 23, 2013 | 10:44 AM
wilcar's Avatar
wilcar
1984 just requires an 85.5" belt.
To Smog pump removal
