C4 head ID ... and advise needed
Old Jan 24, 2013 | 11:27 PM
GT2Race's Avatar
GT2Race
Default C4 head ID ... and advise needed
Blew one head gasket big time ... so the Questio is ... what heads do I have on this 84 C4 Std coupe 350- 5.7 auto / and cross fire inj
do they have the 202 valve size already ?
and are they better heads than
Old double 441 fuelie 327 heads from back in the day
Just happen to have a set ... 202's
my machinist says that the stock 84 vette heads are a much better design and stick with what I have .. flow is the best
advice is good
Lawrence from Montclair So Cal
Old Jan 25, 2013 | 12:05 AM
84wannabezo6's Avatar
84wannabezo6
The 84 came with 624 heads they do have 202 intake valves and they have big 76cc chambers and this year they have flat top pistons with a trough for the valve relief so they used a thin .015 head gasket
Old Jan 25, 2013 | 12:08 AM
cv67's Avatar
cv67
St. Jude Donor '05
Do the 441s have bolt holes in the front if not your accessorys wont bolt up. Dont know if you have 624s or 882s. Geussing someone added the larger valves?
http://purplesagetradingpost.com/sum...fo/heads1.html
Need to find your CC size you require
Old Jan 25, 2013 | 12:49 AM
GT2Race's Avatar
GT2Race
I do know that the 441 heads have a few extra holes that were drilled and tapped in .. the last owner claimed i was setup for a belt drive and would accommodate the heavy 84 accessory package on the 84 vette ..
will verify once the heads are pulled off my C4
how will i know if the heads are 624's or 882's
can I assume that the casting numbers will tell the tail
my machinist dude is claiming that they will be the 882's
is that a win if they are 882's and what is the difference between the 624's and the 882's
Old Jan 25, 2013 | 12:52 AM
cv67's Avatar
cv67
St. Jude Donor '05
havent seen #s on the 624s bet they are super close.
Basic smog head small valve deal. And very crack prone, thin castings. 882 not much better
Casting # youll see when you pull the valve cover off look for a stamped PN look at the last 3 digits.
Old Jan 25, 2013 | 01:10 AM
GT2Race's Avatar
GT2Race
Default Vette heads ....
I will keep my fingers crossed for No crackems in The Heads ... Amen
Old Jan 25, 2013 | 01:12 AM
cv67's Avatar
cv67
St. Jude Donor '05
Have them magnafluxed
Old Jan 25, 2013 | 01:48 AM
vetteoz's Avatar
vetteoz
Basic smog head small valve deal. And very crack prone, thin castings. 882 not much better.
Well documented to be some of the worst heads Chevy ever made
http://www.thirdgen.org/techboard/po...260-post9.html
http://forums.off-road.com/gm-standa...tml#post146960
http://www.chevelles.com/forums/show...91&postcount=4
Old Jan 25, 2013 | 02:05 AM
vetteoz's Avatar
vetteoz
old double 441 fuelie 327 heads from back in the day
A much better head but the 64cc chamber of the 441 is going to bump your CR from the adv
9.0:1 of the '84 L83 CFI to approx 10.2:1
L83 Heads
Casting number 462624
Heads: Iron,
Chamber Volume: 76cc
Intake Valve size: 1.94"
Exhaust Valve size: 1.50"
Intake Port Volume: 158cc
Old Jan 25, 2013 | 02:23 AM
GT2Race's Avatar
GT2Race
Default Im feeling Humpped ...
Shocking .. Im officially lost .. So .. would that be a yesser to convert to the older Fuelie 441's with some 202's and 64 cc
I feel assimilated at the moment .. hopefully things will sort themselves out ..
forgive my senior moments here
I will verify more stats when I can get these heads off
they will either go to the round file or I will go to the round file
somethings gotta go .. just not sure now
thanks for the reality check list .. Ill confer more
Lawrence from Montclair So Cal style
Old Jan 25, 2013 | 02:28 AM
GT2Race's Avatar
GT2Race
Default streetable or not
L83 Heads
Heads: Iron,
So .. can I run california pump gas with 10.1 comp ?
Old Jan 25, 2013 | 02:34 AM
GT2Race's Avatar
GT2Race
Default a bad note ....
Well .. thats not sounding like a a good note ... sounds like Im headed due south .. with the maybe 882's
what now ?
Old Jan 25, 2013 | 02:36 AM
cv67's Avatar
cv67
St. Jude Donor '05
WTH does that number say I cant read it
Old Jan 25, 2013 | 03:04 AM
vetteoz's Avatar
vetteoz
3886336
but not his.
He quoted the pic from my post on where to find the head casting #
Old Jan 25, 2013 | 03:09 AM
vetteoz's Avatar
vetteoz
Yes and not
Heads will be a perf improvement esp the increase in CR but you are still stuck with the cr*p CFI intake
and wimpy L83 cam so you may not see any improvement.
Compare the CFI intake ports to a reg SBC port; notice a problem
To C4 head ID ... and advise needed
