1996 fuel filter
Old Jan 25, 2013 | 12:10 PM
superjet701k's Avatar
superjet701k
Default 1996 fuel filter
Where is the fuel filter in my 1996. It has 98k and I'm sure never been changed knowing the guy I purchased it from . How easy to change.
Old Jan 25, 2013 | 12:22 PM
Just BOB's Avatar
Just BOB
Passenger side on the back side of where your right foot falls when sitting in the passenger seat. I haven't done mine yet, but it has been suggested here on the forums that you remove the right hand lower fender section behind the front wheel. This is the same panel you remove on the left side to remove the main battery. This about the only way to get a wrench on the top fitting on the filter.
Old Jan 25, 2013 | 02:17 PM
superjet701k
Thank you kindly
Old Jan 25, 2013 | 06:41 PM
RUU's Avatar
RUU
Easier to just disconnect the braided line at the fuel pressure regulator that goes to the filter. You'll need a fuel line disonnect tool, but they're pretty cheap compared to trying to undo that front line at the filter.
Old Jan 25, 2013 | 10:31 PM
Just BOB's Avatar
Just BOB
Sounds like that would be much easier. Thanks for the tip.
Old Jan 25, 2013 | 11:45 PM
mtwoolford's Avatar
mtwoolford
I changed the fuel filter on my 96 from the bottom; no hassle except getting my fat **** under the car using just wheel ramps under the front wheels.
be forewarned that whichever way you get to the fuel filter, that you will spill a significant amount of gas. so be careful; once you get the original loosened, have the new one right at hand (not on some bench on the other side of the garage) ready to go right in .
Old Jan 26, 2013 | 12:07 AM
superjet701k
Cool good advice thanks, I was planning on bleeding off fuel pressure either pull fuse and start engine or schrader valve and bleed off pressure ,
Old Jan 26, 2013 | 12:15 AM
Just BOB's Avatar
Just BOB
Yeah, It helps to wait until the fuel level in the tank is near empty. Also loosen the gas cap to relieve any pressure in the tank, then tighten it back up.
Old Jan 26, 2013 | 10:25 AM
Red89'-L98's Avatar
Red89'-L98
FL Events Coordinator
St. Jude Donor'13
I did mine a couple weeks ago on an 89 but it still the same.
I waited until about an 1/8 of a tank of gas and then I pull the fuel pump fuse and started the car until it died. Then I opened the gas tank cap. barely any fuel spilled out when I did this, all I had to do was just hose a little bit off because I like to be cautious when it probably was not even necessary (Just some dribbles from what was still in the line).
Old May 23, 2013 | 03:20 PM
mixalive's Avatar
mixalive
On my 92, I took a Craftsman wrench, I think a 17mm (whatever the size is on the filter) and bent the open end 90 degrees. I had to torch it for a while until red hot to bend it. I then put a pipe through the closed end of the wrench. It will reach up to the top of the filter. Works much better than trying to reach up there with your hand for the hold wrench. I use a flare nut wrench for the fuel line flare nuts.
With all the ethanol in the fuel today, you will be changing the filters more frequently as ethanol absorbs moisture from the air and gets caught in the fuel filter/water separator.
Just saying..
Old May 23, 2013 | 04:19 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
You torched a fuel line? Mine is easy to change with the aftermarket cat on it, lots more room.
Old May 23, 2013 | 04:48 PM
Just BOB's Avatar
Just BOB
No, he torched a Craftsman combination wrench so he could bend the open end 90°
Old May 23, 2013 | 04:55 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Good idea.
That's what I use Craftsman wrenches for, making special tools.
Until Harbor Freight came along.....
Old May 23, 2013 | 06:47 PM
kimmer's Avatar
kimmer
Guess I need to slow down on my reading.
Old May 23, 2013 | 10:36 PM
LT4 F45's Avatar
LT4 F45
Easy to do when you take your time but take the fuel pump out and start the engine till it died before you undo the filter coupling hoses...
To 1996 fuel filter
