Scan tool
Old Jan 25, 2013 | 04:17 PM
482vranger's Avatar
482vranger
Default Scan tool
What is a good,basic scan tool that would work on obdi and obdii. I was told at a parts store that even the $200 obdii scanners would only show basic codes on my 92 vette, said I would still have to count flashes on the dashboard light. I told him I had a paperclip that would do that. Thanks ahead of time for any help.
Old Jan 25, 2013 | 06:19 PM
wilcar's Avatar
wilcar
I have an Actron CP9145 OBD I and II that I bought at amazon for $99. This model is no longer made and is superceded by CP9190 and is $245 at amazon and includes cables for just about every vehicle. It will give you live data too just as my CP 9145 has. There is a CP9145 listed on ebay and current bid is $39.
Old Jan 25, 2013 | 06:26 PM
WW7's Avatar
WW7
AutoXray 6000 scanner will give you all the information you need..Good for OBD1 and OBD2 cars..I also have Datamaster program on my laptop , but the Autoxray works so well I seldom need to hook up the laptop....WW
Amazon Amazon
Old Jan 25, 2013 | 09:53 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
If you just want to know what ECM, CCM, etc codes are being set, you can do this via your dash.
Here's a link http://tech.corvettecentral.com/2011...trouble-codes/
Old Jan 25, 2013 | 11:01 PM
93Rubie's Avatar
93Rubie
Or you can stop messing around and buy a real entry level pro scan tool.
I have a barely used OTC Nemisys that does ALL Domestic OBD1 80's-95. ALL Domestic and Asian ODBII 96-2007. I got it for $400 on Ebay.
On my 93 it does codes, live data, Freeze frame, record,playback, etc...
for ALL modules that support it. ECM, CCM, ABS/ASR, Airbag, etc....
The ECM data is the best. Have a misfire? Look at the low res. signal and high res. signal from Opti-Spark, if all is good. Probably not the Opti-Spark. Cannot do that with a code reader or flashing codes.
It will meet all your needs unless you need bi-directional control and programming type functions for flash-able modules such as the C4 LT1 94-96 ECM.
Old Jan 26, 2013 | 04:49 AM
the blur's Avatar
the blur
My autoxray has major problems. It's a POS.
Old Jan 31, 2013 | 10:37 AM
482vranger's Avatar
482vranger
Default scan tool
I just ordered a innova 3140, $200 at walmart. Does obdi and ii,with live data and can. Guess I will see how good a tool it is. It will take a week to get here so I will post later how well it works. Thanks for everyones input.
Old Jan 31, 2013 | 09:54 PM
scooter mcfly's Avatar
scooter mcfly
Looking forward to hearing what you have to say about the Innova.
To Scan tool
