Fuel rail bolt size/thread
Old Jan 27, 2013 | 10:07 AM
The Bus's Avatar
The Bus
Default Fuel rail bolt size/thread
What is the size and threads per inch on the tiny bolts that hold the cross tubes between the rails and hold the tubes in the rail/"o" ring?? One is stripped. Is there room to drill tap to increase the size by one? #$%^&*()_)(*&^%$#$%^&*()_+_)(*&^%$%^&*() _)(*&^%$%^&
Thanks for all info
Old Jan 27, 2013 | 11:38 AM
WVZR-1's Avatar
WVZR-1
Thanks for all info
L98, LT1 early before '94 or LT '94 & later
The hardware all years isn't dimensional in the catalog - just part #'d. Take a fastener and go shopping for a nut that fits, should be metric or use a screw-pitch gauge to check. I'd consider maybe once you find the size maybe epoxy or JB Weld a stud of the same size in the rail and use nuts to secure it. A stud in 5mm or whatever it is won't be easy to find but I'm sure it can be. Did you ruin 1 or more?
