Pad recommendations for new rotors
Old Jun 13, 2002 | 04:18 PM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
Default Pad recommendations for new rotors
I'm going to put new rotors on the front of the 84. What pads are good with new rotors? The last thing I want to do is warp these new ones.
Old Jun 13, 2002 | 04:26 PM
65Z01's Avatar
65Z01
Default Re: Pad recommendations for new rotors (Mark 84ltblu)
I just installed Raybestos PC Plus semi-metallics on the rear (with old rotors) and they seem to be fine.
Take the time to "bed" the new pads and you will be fine.
Old Jun 13, 2002 | 05:53 PM
John Row's Avatar
John Row
Use your old pads.
If you can't use the old pads, then with new ones stay away from heavy braking for the first 1-2K miles (i.e. No 120-50 in 100') type stops. Normal everyday driving (not normal Vette driving) type stops are OK. Then at the 2K mark bed pads and rotors properly, i.e. heat them up slowly, keep them hot for 10 minutes, cool down slowly and no parking brakes (rear pads).
[Modified by John Row, 3:53 PM 6/13/2002]
To Pad recommendations for new rotors
