Radiator Fan Temps Settings
Old Jan 28, 2013 | 08:29 AM
PG-LT4's Avatar
PG-LT4
Default Radiator Fan Temps Settings
Can any one tell me what the factory fan temp setting are suppose to be for a 96 LT4?
Mike
Old Jan 28, 2013 | 02:00 PM
AirForceOne!'s Avatar
AirForceOne!
I believe 228 deg?
Old Jan 28, 2013 | 07:23 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Mike
Section 6-639
The PCM will command low speed fans ON at
104°C (219°F) and OFF at 98°C (207°F) and, high
speed fans ON at 109°C (228°F) and OFF at 103°C (214°F)
Note: On the '96, both fans run together (either low or high).
Also, Running the A/C will cause the fans to run.
Old Jan 29, 2013 | 04:33 AM
lt4obsesses's Avatar
lt4obsesses
Originally Posted by AirForceOne!
I believe 228 deg?
Primary @ 228
Secondary @ 230
Old Jan 29, 2013 | 07:13 AM
PG-LT4's Avatar
PG-LT4
Thanks everyone!
To Radiator Fan Temps Settings
