Underdrive Pulleys....
Old Jun 13, 2002 | 04:54 PM
Kieran Cox's Avatar
Kieran Cox
Default Underdrive Pulleys....
Does anyone know what serpentine belt fits with the Crank/Alternator pulley set?
I have my pulleys installed, but my serpentine belt is now quite loose, it will shriek if you hit the gas.
TIA for the help! :seeya
Just checked the archives and found a solution, part# 25-060860 from NAPA.
[Modified by Kieran ***, 2:58 PM 6/13/2002]
Old Jun 13, 2002 | 05:06 PM
Raysur's Avatar
Raysur
Default Re: Underdrive Pulleys.... (Kieran ***)
Just cut your old belt and run it around the pulleys like you were installing it. Then cut off the excess. Measure it and go get a new one. :cheers:
