Rear gears and trans help
Old Jan 28, 2013 | 11:37 PM
c4killer's Avatar
c4killer
4th Gear
Default Rear gears and trans help
Been lingering around the forums for the past year and finally decided to make an account so I can get some help finishing my car. It an '85 automatic and has came a very long way since I got it two years ago. Long story short I was ready to sell it when the motor went on me. Instead of parting it out I decided to drop a carb'd 355sbc in it. Of course I wanted more power and slapped a 144 weiand blower on it too. Decided that I wanted this to be a 1/4 killer, I purchased a 3500 stall and sent the trans out to get rebuilt and a reverse manual valve body. Now I see 2 issues that are holding back my project.
What are the highest gears I can use with my stock carrier and do I need a new shifter? Keep in mind that I am going for a pro street style car. Thanks, Anthony.
Here are some pics for those who are curious.
Old Jan 29, 2013 | 12:06 AM
383vett's Avatar
383vett
Nice ride. No matter how many times I look, I can't see that blower setup fitting under the stock hood. What am I missing? If this is an all out race machine, no matter what gears you put in the Dana, they will blow with sticky tires and the hp of a blower. Gotta go straight axle or you'll risk your car or your life.
Old Jan 29, 2013 | 12:25 AM
vetteoz's Avatar
vetteoz
Not to mention
http://forums.corvetteforum.com/c4-t...lf-shafts.html
http://forums.corvetteforum.com/1571010479-post19.html
Old Jan 29, 2013 | 01:39 AM
gerardvg's Avatar
gerardvg
I have twisted my half shafts with only 8 psi boost...
Have replaced them with steel ones and the dana 36 still lives with the 3.07 gears, the tires break loose easily that is probably why the D36 is still alive. Torque is the killer...
For sticky drag racing tires the ford 9 inch diff is the only way to go.
Old Jan 29, 2013 | 06:42 AM
vetteoz's Avatar
vetteoz
Some clarification.
If stock your auto car has a Dana 36 rear ( think 10 bolt / 8" ) .3.73 gears available
Is a bolt in swap to install the much stronger unit Dana 44 unit that came in the man cars ( think 12 bolt / 9" ) . 4.10 gears available
Both styles use identical components outboard of the diff; uni's , half-shafts , stub axles and suspensions items
BUT;
The geometry of the C4 IRS setup is not the best for drag racing , it places big loads on items as the rear squats on acceleration because the half shaft doubles as the top arm of the suspension as opposed to having a separate top and bottom arm with a half shaft that only sees rotational loads as used in the Viper and later Vettes
Many parts can be upgraded but you are only as good as your current weak point leading to the failures I linked above.
http://forums.corvetteforum.com/1564959552-post7.html
Many serious racers have put lots of time and $$$ into keeping the IRS in the car, ultimately going to a solid rear and almost universally stating that they wished they had made the move sooner
http://forums.corvetteforum.com/c4-t...-irs-work.html
http://forums.corvetteforum.com/1572139196-post7.html
Old Jan 29, 2013 | 10:33 AM
383vett's Avatar
383vett
Or a 12 bolt
Old Jan 29, 2013 | 01:28 PM
c4killer's Avatar
c4killer
4th Gear
Thanks for all the helpful response. To start off, the blower does not fit underneath the hood, I still need to cut that out.
Anyway, I tried explaining all these IRS issues to my dad but hes convinced that we can throw a set of 3.73s in there and be fine. I really wish there was a way to do a straight axle set up that wouldnt cost me an arm and a leg. What set up does 383vett have? Thats what Im going for, fat tires in the rear and the front tires off the ground!
Old Jan 29, 2013 | 04:45 PM
vetteoz's Avatar
vetteoz
As per the link.
longevity is directly related to how hard you can launch
If your engine is a good as you think it is take a trailer with you on your 1st outing with the stock D36
Old Jan 29, 2013 | 05:17 PM
383vett's Avatar
383vett
That's a Strange 12 bolt setup. Not inexpensive.
Old Jan 29, 2013 | 10:06 PM
Phat98's Avatar
Phat98
...but looks pretty damned good sitting under there.
Old Jan 30, 2013 | 01:21 AM
c4killer's Avatar
c4killer
4th Gear
Well at this point im hoping the 3500 stall will help me out a little. If it blows it blows. Would it be worth throwing gears in the diff I have now to buy me some time? Honestly I need to to last at least 3 runs because I need this thing running low times for a big money race as soon as its finished.
Old Jan 30, 2013 | 01:43 AM
vetteoz's Avatar
vetteoz
Would it be worth throwing gears in the diff I have now to buy me some time? .
No
Because D36 gears are expensive ,better to put the $$ towards the stronger D44
A lower gear set will generate more torque so you will be putting more load on the outboard parts
http://www.viperclub.org/howto/faqs/...-gear-swap.php
http://www.carcraft.com/techarticles...s/viewall.html
Run street tires and let it spin all the way through 1st
Old Jan 30, 2013 | 06:25 AM
Glenno's Avatar
Glenno
Do you have any pictures of your straight axle that you can post? Where do you purchase such an axle? Or do you build it yourself? Thanks
Old Jan 30, 2013 | 07:41 AM
vetteoz's Avatar
vetteoz
Get your wallet out
http://www.rodandracecraft.com/products_corvettec4.htm
http://forums.corvetteforum.com/drag...-axle-kit.html
Several have done their own installs
This member's one uses a torque arm
http://www.bowtye8.tzo.com/bowtie8/C...5/9Inch_TN.htm
This is a more conventional setup
Old Jan 30, 2013 | 10:38 PM
Glenno's Avatar
Glenno
That stuff is for serious drag racing only? What does a straight axle do to the handling of the Corvette? Does it take away from the handling especially in the turns? Thanks.
Old Jan 30, 2013 | 10:50 PM
vetteoz's Avatar
vetteoz
TWhat does a straight axle do to the handling of the Corvette?
Does it take away from the handling especially in the turns? .
Plenty of race cars that go around corners use a solid rear
http://forums.corvetteforum.com/1564066339-post13.html
Old Jan 31, 2013 | 10:31 AM
383vett's Avatar
383vett
My car handles like poop with skinnies and drag shocks in front and a spool out back.
To Rear gears and trans help
Old Jan 31, 2013 | 11:16 AM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Yeah, but I've never heard anyone swapping from an IRS to a solid rear axle to help handling...I've certainly heard going from a solid rear to an IRS to help handling though. You can't beat negative camber and toe-in in the rear to help corner entry and exit.
Old Jan 31, 2013 | 05:05 PM
vetteoz's Avatar
vetteoz
You are not doing a solid rear for corner handling.
You are doing it for traction and strength on hard launch ie, the strip
Some as in the link I posted drive their car to the track
Old Jan 31, 2013 | 08:59 PM
Phat98's Avatar
Phat98
Dammit, boy...how fast are you taking those turn-off lanes???
