Help with codes !!
Old Feb 1, 2013 | 11:04 AM
Mohammed_z's Avatar
Mohammed_z
Default Help with codes !!
I had these six codes pulled from the ac display.
I couldn't find a reference for the codes here !! what are they ?
car is a '94
64 , 139 , 97 , 198 , 176 , 02.
Old Feb 10, 2013 | 11:51 AM
Fastz51's Avatar
Fastz51
7th Gear
Default 94 trouble codes
car is a '94
DTC 64 - Bank 2 (Right Front) Heated Oxygen Sensor (HO2S) #1 Circuit (Lean Exhaust Indicated)
DTC 97 - VSS Output Circuit
The other codes 139,176,198 do not exist. Make sure you have the right codes.1994-1996 Corvette ECM, CCM and ASR/EBTCM codes are accessed placing the jumper wire in ALDL connector positions 4 and 12. GM used numerals in place of alphas on all 1994 and up Corvettes at the ALDL. The ALDL numerals start with 1 in the upper left hand position and 9 in the lower left position. Install one end of the the jumper wire 4 positions from the upper right. Place the other end of your jumper wire in the position directly below number 4.
http://tech.corvettecentral.com/wp-c...4-1024x680.jpg
Fastz51
Old Feb 10, 2013 | 12:38 PM
Mohammed_z's Avatar
Mohammed_z
I think I did a mistake by pulling the codes from the Air conditioning screen !! Am I right ?
I didn't do the jumper way !! What after installing the jumper ?
Old Feb 10, 2013 | 11:00 PM
vetteoz's Avatar
vetteoz
Read the codes displayed in the speedo
http://tech.corvettecentral.com/2011...trouble-codes/
Confirm which MODULE you are pulling the codes from
CCM /PCM / ABS / etc
Old Feb 11, 2013 | 10:07 AM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
Try this link for A/C Codes.
http://forums.corvetteforum.com/c4-t...ble-codes.html
To Help with codes !!
