Coolant temp sensor part number for 86
Old Feb 1, 2013 | 01:37 PM
sansonic's Avatar
sansonic
Default Coolant temp sensor part number for 86
Real quick question guys i am going to replace the coolant temp sensor that is under the throttle body. I believe it is the one that goes to the ecm. I am just want to make sure this is the right part number. From rock auto (ACDELCO Part # 213928 {#15326386} 2-WAY MALE
Category: Intake Manifold Temperature Sensor).
Thanks in advance i would hate to waste 15$ and shipping only to find out its the wrong part for my 86.
Old Feb 1, 2013 | 02:48 PM
WVZR-1's Avatar
WVZR-1
Why wouldn't you buy it local? For an '86 you might need a connector also if it's never been changed!
Old Feb 1, 2013 | 02:58 PM
sansonic's Avatar
sansonic
I'd buy it local but we only have advanced auto parts and other similar stores around here and they want 30$ for the same part! If anyone knows where i could get the connector for the sensor that would be great to.
Old Feb 1, 2013 | 03:07 PM
WVZR-1's Avatar
WVZR-1
I only see 21.49 local @ Advance and I didn't even shop!
Old Feb 1, 2013 | 10:00 PM
sansonic's Avatar
sansonic
Thank you for the advice but i still really need to know if it is the correct part.
Old Feb 1, 2013 | 10:32 PM
WVZR-1's Avatar
WVZR-1
I thought when I mentioned local you would "pick up on" it's the correct part! Sorry. Yes you should be good. You can check the connector before hand and if it matches the switch/sensor you'll be fine.
http://webcaps.ecomm.gm.com/internet...artnbr=213-928
Old Feb 2, 2013 | 08:05 AM
sansonic's Avatar
sansonic
Oh okay thank you for all the help.
To Coolant temp sensor part number for 86
