Tilt Steering fix
Old Jun 14, 2002 | 11:19 AM
jtfrog's Avatar
jtfrog
Default Tilt Steering fix
I have an 86 corvette with tilt and the colum is all loose. I have done reading on how to fix this but is it hard or worth doing myself or should I have it fixed. Any ideas on how much to fix or links on how to fix mylsef
Old Jun 14, 2002 | 07:26 PM
blk90rdstr's Avatar
blk90rdstr
Default Re: Tilt Steering fix (jtfrog)
Its a little tricky to get at the bolts that are loose. You just need the right tools. Like wheel puller a lock plate tool and long torx drivers. Occasionally these bolts are broken, not loose. in that case a rebuild is needed. :smash:
Old Jun 14, 2002 | 07:32 PM
Corvette0096's Avatar
Corvette0096
http://www.aros.net/~rbuck/column/tiltcol.html That should help.
Corvette0096
Default Re: Tilt Steering fix (corvette0096)
Welcome to the forum!! :seeya
Old Jun 15, 2002 | 01:26 AM
Bluevette85's Avatar
Bluevette85
You'll also need this tool from Harbour Freight:
Steering Pin Removal Tool
Old Jun 15, 2002 | 06:21 AM
JonM's Avatar
JonM
Here is another
http://www.gnttype.org/techarea/susp..._steering.html
Old Jun 15, 2002 | 07:18 AM
Rich B.'s Avatar
Rich B.
One comment here: The $7.95 price for the lockspring tool at AutoZone is to *rent* it. It's ~$16 to *buy* it...
To Tilt Steering fix
