AC Troubles
Old Jun 14, 2002 | 02:27 PM
kingvet's Avatar
kingvet
Default AC Troubles
Does anyone know the cause and repair for the AC blowing out of the defrost and floor vents. I know Ive seen this topic before but cant remember the cure. Any info or parts required would be helpful. My car is a 1996 coupe with a LT4 and manual climate controls. :chevy
[Modified by kingvet, 6:28 PM 6/14/2002]
[Modified by kingvet, 6:42 PM 6/14/2002]
Old Jun 14, 2002 | 02:37 PM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Default Re: AC Troubles (kingvet)
Chris, ONE of the causes could be a vacum leak in the sending unit (the piece that is in your dash) Is you unit climate control or manual? I remember somebody getting a in dash CD unit installed and the installer accidentally snapped on of the vacum lines and caused the same thing your dealing with...just a thought..Good luck :cheers:
Old Jun 14, 2002 | 02:38 PM
Blue88's Avatar
Blue88
From my past experience auto climate control anytime there is a problem with a vacuum actuator that directs the airor if there is a broken vacuum line going to the climate control, the default is that all air goes to the defrost. I may be way off but it sounds like a vacuum leak to me.
Old Jun 14, 2002 | 02:40 PM
Flame Red's Avatar
Flame Red
Their should be a small vacuum 'T' fitting under the fuel rail cover. Take it off and check (or just replace it), it usually leaks from decaying with heat.
xzvs's Avatar
xzvs
Default Re: AC Troubles (Blue88)
yup --its usually the vacuum feed from the engine.
To AC Troubles
