Coolant in the OIL
Old Feb 11, 2013 | 05:57 PM
aboatguy's Avatar
aboatguy
Default Coolant in the OIL
I keep reading posts regarding head gasket, cracked blocks etc IRT coolant in the OIL. I have only found coolant in my oil once. It was a many years ago back before my high RPM days.
Any way the head gasket was perfect.
The problem was:
Its been long enough that I can chuckle about it now; I babied that engine and it didn't pay off hence, been beating its replacement like a 2 dollar mule.
Post your heinous grenade pictures
Mike
Old Feb 11, 2013 | 07:23 PM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
Yep, that will definately put coolant in the oil.
Old Feb 11, 2013 | 07:51 PM
leesvet's Avatar
leesvet
that had to hurt
Old Feb 11, 2013 | 09:52 PM
cv67's Avatar
cv67
St. Jude Donor '05
Retainer pull through broken spring?
Old Feb 11, 2013 | 10:23 PM
Photomania's Avatar
Photomania
How long did you drive it like that? What did it sound like?
I had two cylinders that would stop firing when the engine got warmed up. Whole car would shake, but not terribly. I replaced all of the fuel injectors and that solved the problem.
Old Feb 11, 2013 | 10:29 PM
aboatguy's Avatar
aboatguy
Spring was Intact and still together with valve stem....
We believe something happend to the valve seat on the exhaust side.
Took a second or two of tap tap like loose rocker to steam plume from hell and motor lock up. No joke it was iiterally tap tap boom..
Car filled with steam, I thought I had a fire got out of car and water was pouring out of exhaust. I was in my summer whites, digging through the carnage....... Ended up buying new whites too.
Mike
Old Feb 11, 2013 | 10:36 PM
383vett's Avatar
383vett
That is an ugly picture.
Old Feb 11, 2013 | 10:37 PM
aboatguy's Avatar
aboatguy
Sorry was replying to the previous post when yours hit...
The engine hydrolocked if you look at the head you can see evidence of the water mix in every cylinder. I guess it got forced through the intake or threw the bottom.
click click boom......but quicker than it takes to read click click boom. But it happened merging onto a 80mph highway... so figure 35-50 revs per second....
Old Feb 11, 2013 | 10:38 PM
aboatguy's Avatar
aboatguy
Waiting for folks to show their ugly pics I know they are out there...
MIke
Old Feb 13, 2013 | 02:11 AM
Phat98's Avatar
Phat98
So I'm assuming a little JB Weld was out of the question?
Seriously, though...OUCH!
Old Feb 13, 2013 | 12:57 PM
fredd1's Avatar
fredd1
My first guess would've been the head broke off the spark plug (wrong depth plug), but the damage looks too severe even for that. Inclusion/weak spot in the casting maybe?
Old Feb 13, 2013 | 01:07 PM
ch@0s's Avatar
ch@0s
MIke
Cheap cam from Ebay gave up the ghost right at 1K Its hard to tell but inside that dimple it looked like cottage cheese.
To Coolant in the OIL
