C4 Lt1 to Ls2 T56
Was big into Audi, 2000-2002 S4 2.7TT. Owned 3 all modified beyond belief but the 2.7l im begining to realize is quite a joke and ready to move to a corvette, always liked these
So I'm the type of person who works on my cars and ive done numerous engine pulls etc etc. I was looking into getting a Lt4 corvette but im not liking the idea of the iron engine block. However i do like the idea of the LS1 or LS2. More modern
Ive been reading guides of doing a Ls2 and T56 into a c4 corvette. A 2005 GTO would be my donor car that i would later part out to recoop. and use the engine and trans in the LT1 corvette . The conversion does not seem overwhelming to me and seems do-able.
Has anybody done this before that is willing to chime in on their final product if the like results.
I would do the swap and keep facoty tune and internals etc for reliability at this point in time. Looking for a nice powerful car to whoop on during the weekends!
What do you think?
Here is the thread where we collaborate it has muncho info.
http://forums.corvetteforum.com/c4-g...x-swaps-8.html
Here is my thread.
http://forums.corvetteforum.com/c4-t...x-my-swap.html
Here is my car runing but not driving yet.
Slide show:
Scary's car on the dyno
Here is an E-rod LS3 in a c4 belonging to forum member
3D87C4
http://forums.corvetteforum.com/c4-g...-erod-ls3.html
I did all the work and wiring and sold off my engine and other stuff. I also took my sweet time sourcing parts.
This was posted March 8th 2012 I havent spent much more maybe fluids and such but that would be needed swap or not.
so far
Engine, Ecu and wiring $1300
additional wiring and connectors $90
Transmission and converter $1750
Racetronix 255 Fuel pump kit $120
Speehound motor mounts $100
Advanced Adapters 4L60E to 700R4 tail shaft adapter $214
A/C compressor high mount adapter $150
Corvette power steering pump,bracket and pulley $140
Corvettte alternator $100
Powerbond balancer $145
98 Corvette Batwing oil pan and C5 manifolds $50
Oil pan gasket $50
Starter from fleabay $56
Balancer bolt $14 gm
Hoses, and fuse block $80.00
TB cable $50
Tuning $100
Two O2 sensors $120
wirring and terminals $60
Transmission cooler and lines $220
Fuel lines and fittings $145
Radom Tech Cat cons $200+100 fab work
I might need to get a couple of Dakota Digital boxes
A/C lines and Compressor
Spent $5354.00 and some of this stuff is optional.. for example you dont have to spend $550 on a converter
So far I have made $2945 to offset the cost from sales of my old stuff. I still have a few parts lying around.
I would be buying a 84-91 LT1 Vette, which ones the best years? and a 05-06 GTO T56 in a collision to be a donor car. I have a feeling itd be a good idea to have all the extra parts for some retro fits needs
Hopefully i would be able to get a vette for 6-7k GTO for 6-7k. Have the engine and transmission from the vette to sell along with the rest of the GTO to part out on ebay.
Did you really drag it out, or is it very complicated? It looks pretty straight forward, swap the engine and trans, get all the wiring figured out to the dash, install GTO pedals along with other miscellaneous things that need to be figured out.
The early cars are easier only because of the gauges and wiring, no CCM. BTW what "guyde" is this you speak of?
What do you mean guyde? haha im confused.
No emmission here
Ill prolly be running dual 3in exhaust with single magnaflow or flowmaster custom built by yours truly
No cats yippie!!
My "LS3"/T56 swap is here, although only about 10% of the work is documented online.
http://forums.corvetteforum.com/c4-t...p-started.html
Took me just over 2 years, but that was mostly because I bought a few parts each month and it took that long to pay for them.
Your right my mistake.
Im definitly not a weekend tinker. Im a mechanic for my job and have a full service shop at my disposal
I will be keeping all factory internals on the LS2, btw.
So the CCM is central control module i take it?
What in the world does it even do? Haha
Wiring is going to be my biggest concern so the 84-87 sound like the best options unless the CCM is easily solved?
Also does it matter if i get an auto or manual in the corvette? Cluster coding?
Sorry im a noob
Sorry im a noob
... The auto is easier to do. Look at Mike's thread if you are doing a manual. To do the auto you either stick with the 700R4 (beefed up) or go with a 4L series and use an adapter for the tail shaft. I think you have to fab your own if you go manual.
Also, you can get adjustable springs for the later years which make it easier to compensate for the lighter engine. In the earlier models your only options are wedge removal or coil over conversion, and that can be problematic too from what I've read.
Or would it be a better idea to eliminate the entire stock harness and get an aftermarket one, or is that unnecessary because piggybacking is easier than it sounds?
