Just drove my 90 after installing new memcal. Runs good but GPS said speedo was 5 mph fast at 50. Now the fun begins. This car came with a 2.73. Buildsheet says the prom was programmed for a 2.73. I turned the driveshaft and counted one tire revolution-3.07. Took out the vss and found a red drive gear and green driven gear. Chart says red-blue is correct for a 2.73. Chart says red-green is correct for a 3.07, but......counted teeth on green gear (four times), 38 teeth. Chart says green gears have 42 teeth, blue gears have 38 teeth. The color is wrong, but the number of teeth is correct for a 2.73. Also bad news because 38 or 42 require a different vss. Can someone help me sort out this mess?
'vert has nothing to do with anything! That's just an WAG guess that's usually correct regarding the 2.73!
Disregard "colors" - for a 3.07 you need a 42 tooth driven and YES it does require a different VSS to get the gear pitch correct. The PROM in your case is "incidental" it's ID by the 2.73 and all 'verts got the 2.73 by default in the build. It has nothing to do with "error" you're seeing. You're seeing something at a 10% error at 50 and that should be consistent percentage wise at any speed. (35 - 38+, 40 - 44, 60 - 66+ etc)
You need to try and find a correct VSS and a 42 tooth gear..
It could likely be done by changing both the drive and driven using the VSS you have but that's a nuisance!
If someone had a '90 M6 on the ground it would have a correct VSS.
If you had your VSS out; there is a stamping of the tooth size...2:59 and 2:73 have the same VSS with stamping of 34-39 in relation to drive gear tooth no. A 3:07 and up has a VSS stamping of 40-45. I have a 1990 Vert also and I went to 3:54 gears from the 2:73's a few years back and had to hunt down a used 3:07 VSS as they are not made anymore just the other VSS. With the correct drive and driven plastic gearing and the right VSS ; I am right on the speedo with a GPS check. Had to research it out for the right combo..forgot the colors of the gears but I remember the driven gear was 43T and if I went with 3:73's like some people have done the driven gear would be a 45T. Dont remember the drive gear tooth no.Just a little more info on your question.
Bill
I remember when you were "struggling" with the speedo and it seems to me you were considering a DRA and I mentioned there was "NO WAY" you wanted any part of that! That was a very long time ago I believe!
Wow..you have a better memory than me. I have been retired for 5 years and the memory is not as keen as it was once...guess its because of my "Artic Blond" hair colour . I replaced the VSS after the install and finally got the right VSS from a forum member in Arizona. Once installed all was well with the GPS check.
If memory serves me I used "MASTERSET" to figure out the gearing which I also got from a forum members site (thanks Vader). Thats all I remember
Bill
There are two VSS versions. One has the shaft in the center. The other is for the larger driven gears and has an offset to move the shaft away from the drive gear.
I see a simple way to rotate my old vss 180 degrees if that will properly space a 42 gear (which I found on ebay but haven't received yet). Has anyone had any success with this conversion? I suspect there is really only one vss , because the shaft on my 38 gear vss is not centered. If I rotate it 180, the offset goes from the "top" to the "bottom" if you were looking into the transmission with the drive gear at the top of the hole, so to speak.
If you're willing to have someone burn you a new tune, it can be adjusted in the tune without having to change any VSS gears. It could potentially cause a real nightmare for someone down the road if you sold the car though.
Actually, I am the person down the road who is attempting to return everything to stock. I drew the line at going back to the 2.73, however, so I am correcting the speedometer gearing that wasn't changed when someone put in a 3.07. I had a new memcal burned before I realized the rear had been changed, so it is going to stay programmed for a 2.73. As far as I know, at least through 1993, the. computer does not calibrate the speedometer in a C4. I believe in 100% disclosure when I sell a car. Since I consider myself a "restorer", I know how maddening it can be trying to undo someone's "modifications."
There's multiple errors in that document and a person needs to confirm each and every "detail" before they "assume"! Among the errors are VSS assignments for '91MY, the M6 drive gear for several years. Those are at a "quick glance".
I didn't make the chart and I wouldn't be surprised if there are a few errors. That being said, it has been a great resource to me over the years when changing rear end ratios.
