I have noticed at very low speeds that there is a noticeable howling noise coming from my rearend while turning. I am assuming that this could be the wheel bearings/hubs, etc. Any insight would be very much appreciated.
well, check the bearings. Jack car up and see if grabbing at top & bottom allows ANY wiggle of the wheel...if so, replace hub assy.
IF NOT< then I'd inspect u-joints and rear end for wear/damage. Drain and refill the rear end with the CORRECT grease AND the GM posi-additive...(GM limited slip additive)..some gear lube comes with this mixed in.
