1992 - Can't pull codes
Old Feb 18, 2013 | 02:35 AM
xrsis's Avatar
xrsis
Default 1992 - Can't pull codes
My 92 vette (LT1) is running the fuel very rich. It starts to cut out when accelerating. I took it to a good mechanic, but he said that he cannot pull codes. He is unsure if it is the wiring harness or the computer that is bad. Any suggestions?
Also, the transmission (6spd) is acting up.
Old Feb 18, 2013 | 06:57 AM
vetteoz's Avatar
vetteoz
Originally Posted by xrsis
I took it to a good mechanic, but he said that he cannot pull codes. He is unsure if it is the wiring harness or the computer that is bad. .
How was he trying to do it? with a scanner ?
The correct type scanner ; OBDI not the OBDII scanner that most mechanics have now.
You can try and pull the codes yourself
http://tech.corvettecentral.com/2011...trouble-codes/
If you can't get the codes to display that way then you do actually have a problem
Old Feb 18, 2013 | 07:28 PM
gbrtng's Avatar
gbrtng
Storing and displaying error codes is a basic function of the ECM. If it won't flash 12s, then it is defective - according to my 91 manual. Not sure about 92 ...
Old Feb 18, 2013 | 08:22 PM
vetteoz's Avatar
vetteoz
Same could be true with a wiring problem from / at the ALDL connector
We don't know yet how the mechanic tried to pull the codes.
Going on recent posts from members as to the knowledge of some out there, the quality leaves alot to be desired.
Hence the requirement as a C4 owner to be able to do basic troubleshooting so as to avoid unnecessary "repairs".
The " replace parts until the problem is gone " theory
To 1992 - Can't pull codes
