Bad ECM ?
Old Jun 15, 2002 | 01:58 PM
jeffie86/96's Avatar
jeffie86/96
Default Bad ECM ?
I am having trouble with my 86 and need some input. I cannot get communication with the ECM with both my scanner and my buddys Snap On scanner. We did some further diagnostics and found less than 3.5 volts at pin "K" or something like that. I suspect either a bad wire between the port and ECM or bad ECM. Is there any way of testing an ECM out of the car? :confused: You guys are the best. :cheers:
Old Jun 15, 2002 | 06:46 PM
jeffie86/96
Default Re: Bad ECM ? (jeffie86/96)
Put in a new ECM, runs better!! Still not sure about the communications though, further testing is in order. :yesnod:
