De Plane or dual plane intake ...
http://www.technovelocity.com/chevyh...rt_polish.html
I have a few other links that I have found usefull if you would like.
trips to the beach , and weekend warrior autocross and strip ..than drive to doctors Monday
Budget = SSI fixed income at 63 (a so to limited budget ) but add in free time and good hands
my machine shop closed to public now .. recovering from liver transplant and oldness
I will get those bits .. I have some wax so far.. mostly in ears .. Hah !
trying to source the long bits for my die grinder now ... cant find them yet ..Hmm ?
If all else fails .. super retail Tools-R-Us will have them $$$
BTW, you want "absolute limit..." but are worried about gas mileage??
IMO: Port your intake, throw some GOOD exhaust and a converter at it, tune it. It will be an entirely different car than it is now for <$1000.00 if you shop smartly.
Lawrence fro
m San-Bern
10 miles west of Fontana Speedway
my cell is 909-717-5260
You wont get 5-600 out of it but it can be pretty decent.
Bring your intake out Ill get you started and send you home with a few things to use and a source if you need more.
btw;http://www.carbideplus.com/category_s/350.htm
Sticking to a Massive attack on the X-Fire intake porting chore .. with help and lots of it !
Cmon now .. you get my drift .. wish I had your $$
Im pulling the Die grinder out ... just take that as an indication of my Budget .. lets get on with that one in mind
Can you please advise me on Cam Limits ..
not so much lift but maxxed duration limits .. a need
Want this stock looking 350 to run like a " Budget Motha "
will use a flat tappet hydrollic w/ 1.5 rockers , 624 heads ( maybe a bit of porting-maybe a lot)
stock 700 tranny and converter , same with rear gear ratio ..
Liver transplant recovery and SSI income for a spell .. ah &%%@#
heard a Rumor that you may lend some Wisdom on Cross-Fired Intakes
head porting and Cam limit advise is good
using the crossfire TBI's and Old slow simple ECM .. keeping things simple again ... Bottom line .. Advise is Heaven for this Old Centurien
cheers / Lawrence
As you add duration, you change the SHAPE of the tq curve (given the same displacement). You can change the shape some and get away with it, but as you change the shape more, trying to accomplish fueling for both no load/idle and full load/peak tq w/o ECM tuning becomes impossible.
IN SHORT, I'd keep duration close to stock. I'd keep it around 210* or less. I'd increase breathing with intake, exhaust, and (if funds allow) fantastic heads, and more valve LIFT, then I'd "feed it what it wants", fuel wise, using injector sizing and fuel pressure....just like I did on mine. I ended up using 90pph injectors, 15 PSI "no vacuum" fuel pressure, and I used a Marine TBI application FPR (with my stock spring installed), which is a vacuum referenced FPR and with the spring I used, ended up with a FP of ~10 PSI at idle/18" vacuum. You can play with "ratios" with that FPR by changing springs, injector size and set pressure.
I haven't ported heads so have no advice there. My advice would be to get some used Vortec heads and make them work. But if you have time and don't mind grinding on cast iron...go for it; it's basically free power.
Seems the unit is the heart beat for camshaft limits and much more ...
Assuming, The device is the heart of My C4 350 ... so knowing this
Advise on making the best of this cross fired TBI system is the goal
And .. the how to simply understand what ECM's really control would make life simpler for my Old brain
Advise What add o'ns proms or piggy backs are available and what changes can be made to the give me max performance on this limited ssi income
Free horse power is my best friend
Got die grinder will travel ... all else ... Help needed
Options for the CFI specific computer are replacemnt chips. Hypertech, ADS used to make them, Turbo City, I think did too, and a company called DCS currently makes one. There are two problems with these, as I know it;
1. I have never seen or heard of a chip for a CFI car that made a documented improvement. In fact, all I've ever seen or witnessed is that chips made stock or stockish cars slower.
2. The tune (in the chip) is for the engine/conditions that were present on the day and with the car that the original tune adjustments were settled on. Your car is different, you live in a different place, and you're about to perform hard part changes -which will move the requirements way out of line with what the replacement chip was going for. While the chip should (in theory) be able to adjust for changes in weather/temps/altitude, like I said, I've never seen these chips HELP anything. You can do better "tuning" (I feel) by manipulating fuel pressures and base timing.
What you'd ideally need to do is burn your own chip/tune, that is optimized for your combo. That requires you to change computers to one that has aftermarket/tuning support and hardware, then learning how to tune. A process. This is why I gave you my best advice for what I thought of your situation, above;
'If he can get a a truck TBI computer in there than maybe we can find him a tune. I dont have the kind of time it takes to learn
Doubt the smog guy would notice and if he did it should be a non issue as the 84 stuff is NLA anyway
First thing is geting enough time in that intake..I dont see how the top can be accessed to really go nuts without cutting the outer walls off (welding together later) to get your tool in there. There are extensions to go in from the bottom but that seems like a super huge pain for little progress/time given
Sure would get better results I think and surely save a lot of time.
Up to him though just trying to help out..get the most out of what hes got due to budget.
Those heads well....
sure they can be squeezed for some power though. If the intake exh was decent with a small cam, converter bet he could have a decent running car maybe better than hoped for. It wouldnt lope but so what. thats overrated anyway
