Cam/Tuning the Crossfire
Old Feb 21, 2013 | 02:37 PM
cv67's Avatar
cv67
St. Jude Donor '05
Default Cam/Tuning the Crossfire
Its my understanding those proms are NLA.
So how the hell do you tune one of these if say you stuck a cam in it
Dont know anyone local and cant tune ecms myself.
Member wants to cam his crossfire- nothing radical just to pick up torque..
What are your experiences with camming the Xfire and tuning?
Gotta pass Ca smog.
Old Feb 21, 2013 | 05:47 PM
wilcar's Avatar
wilcar
Comp cams has some computer friendly grinds for the 305-350 engines. Might want to call Isky out your way and see if they have something like their 256 and 262 super cams that will pass Calif. smog. I ran a comp 252HE 206-206 110 lsa in a 305 87 Firebird that had to pass smog in Florida and that cam had a stone stock idle but had much more low and mid range than the stock factory cam. I would think there are some decent cams under 210* duration and on a 110-112 LSA that would give you better low speed torque than the stock 202-206 114 crossfire cam and still pass smog.
Old Feb 21, 2013 | 06:33 PM
hemivett's Avatar
hemivett
I'll give ya a bump. Ive been wondering the same thing myself. Been looking at some of comps thumper cams for EFI, and was wondering where I can get adequate fuel for it. I know the tb's can give upwards of a 1000cfm, (bored, and bigger injectors) but what about the info needed to get it! Maybe someone makes an aftermarket computer? Seems like the 84 is the most challenging to work on, of all the C4's. I bet Tom400cfi has an answer. h
Old Feb 21, 2013 | 06:46 PM
vetteoz's Avatar
vetteoz
What the serious CFI owners use
http://www.dynamicefi.com/EBL_Flash.php
or convert to a TBI truck ECM
http://www.thirdgen.org/techboard/di...ng-tuning.html
Old Feb 21, 2013 | 06:58 PM
cv67's Avatar
cv67
St. Jude Donor '05
Vetteoz does that computer have a reg OBD1 port like if the smog guy plugged in it would fit? If so that opens up cam options
know TBI is real sensitive to overlap so a lumpy cam is out....same with emissions. Know he wants a lumpy idle but not so sure its a great idea unless that truck computer makes it possible.
Picking the cam isnt the chore its how to tune.
Thanks!!
Old Feb 21, 2013 | 08:26 PM
Crepitus's Avatar
Crepitus
here is data log sw for the xfire
http://winaldl.joby.se/
Old Feb 21, 2013 | 10:28 PM
farmer661's Avatar
farmer661
I have an '84 and putting 64 cc Dart heads and a 2040 cam. I will probably need some tuning and intend to go with the EBL Flash and the Ham board. I already have a ported intake and no Cat.
I will send the ECM to each of them and have both added. Not sure of my soldering skills. Is there any logic why I would have one installed before the other, such as testing? I am thinking the Ham first, then the EBL Flash.
Regards,
Ken
Old Feb 21, 2013 | 10:43 PM
cv67's Avatar
cv67
St. Jude Donor '05
Sounds like the best bet in this case is to be conservative limit overlap and shoot for lift...torque like usual. I just dont see computer swaps self tuning etc happening just yet.
Old Feb 22, 2013 | 01:32 AM
714rorer's Avatar
714rorer
1st Gear
0110111001101111011101000110100001101001 0110111001100111001000000110111001100101 0111011100100000011010000110010101110010 0110010100101100001000000110000101110011 0010000001110101011100110111010101100001 0110110000100000011011100110111100101101 0110111101101110011001010010000001101011 0110111001101111011101110111001100100000 0111011101101000011000010111010000100000 0111010001101111001000000110010001101111 0010000001100101011110000110001101100101 0111000001110100001000000111010001100101 0110110001101100001000000111100101101111 0111010100100000011101000110111100100000 0111010101110011011001010010000001100001 0010000001100100011010010110011001100110 0110010101110010011001010110111001110100 0010000001110011011110010111001101110100 0110010101101101001011100010000001001001 0110011000100000011110010110111101110101 0010000001100011011000010110111000100111 0111010000100000011101000111010101101110 0110010100100000011011110111001000100000 0110111001101111001000000110111001101111 0111010001101000011010010110111001100111 0010000001100001011000100110111101110101 0111010000100000011101000111010101101110 0110100101101110011001110010110000100000 0110000100100000011011100110010101110111 0010000001100101011000110110110100101111 0111001101111001011100110111010001100101 0110110100100000011101110110100101101100 0110110000100000011011100110111101110100 0010000001101000011001010110110001110000 00101110
Old Feb 22, 2013 | 12:23 PM
ch@0s's Avatar
ch@0s
0000000000000000000000000111111111111111 1111100000000000000000000000000000000
0000000000000000000000111111111111111111 1111111110000000000000000000000000000
0000000000000000000111111111111111111111 1111111111110000000001100011011000000
0001010110000000011111111111111111111111 1111111111111110000000110110110110000
1101010110000001111111111000011111111111 1100001111111111000000011111111100000
1111111110000011111111110000001111111111 1000000111111111110000111111111000000
0011111110000111111111110000001111111111 1000000111111111111111111111110000000
0011111111111111111111111000011111111111 1100001111111111111100001111000000000
0001111111111111111111111111111111111111 1111111111111111111100000111100000000
0000111000111111111111111111111111111111 1111111111111111111110000011110000000
0001111000111111111111111111111111111111 1111111111111111111110000000111100000
0001110000111110111111111111111111111111 1111111111111111011111111111111111000
0011111111111110011111111111111111111111 1111111111111100011111111111111111100
0011111111111110001111111111111111111111 1111111111110000011110000000000000000
0000000000001111000011111111111111111111 1111111111000000111100000000000000000
0000000000001111100000111111111111111111 1111111100000001111000000000000000000
0000000000000011110000000000111111111111 1110000000000011110000000000000000000
0000000000000001111100000000000000000000 0000000000001111100000000000000000000
0000000000000000111111000000111111111111 1100000000111111000000000000000000000
0000000000000000001111111100000111111111 1111000111111100000000000000000000000
0000000000000000000001111111111100111111 1111111111100000000000000000000000000
0000000000000000000000001111111111111111 1111111000000000000000000000000000000
0000000000000000000000000000000000011111 1111111100000000000000000000000000000
0000000000000000000000000000000000001111 1111111100000000000000000000000000000
0000000000000000000000000000000000000111 1111111100000000000000000000000000000
0000000000000000000000000000000000000011 1111111000000000000000000000000000000
0000000000000000000000000000000000000000 1111110000000000000000000000000000000
Old Feb 28, 2013 | 03:52 PM
Rohn's Avatar
Rohn
Truck ECU 1227747 is not a plug an play. Needs to be hammed. See crossfire diversified solutions for the "board". A 1228746 is a better idea. It supports IAT sensor.
To Cam/Tuning the Crossfire
