Injectors ?
Old Jun 16, 2002 | 06:42 AM
Sliding's Avatar
Sliding
Default Injectors ?
What would happen if connectors on injectors on
cylinders #5 and #7 were replaced ( 5 to 7, 7 to 5 )?
:confused:
Old Jun 16, 2002 | 07:56 AM
Wildride's Avatar
Wildride
Cruise-In II Veteran
Default Re: Injectors ? (Sliding)
Should be business as usual. The L-98 fires its injectors in a "batch", i.e. all fire at the same time, every time.
The LT-1(1992 and up) uses a "sesquential" system where each injector fires in sequence with the cylinder it is serving. If you switched the connectors on a LT-1, you would have troubles.
