Gates Part #s for coolant hoses ?
Old Mar 4, 2013 | 03:46 AM
Blue95C4's Avatar
Blue95C4
Default Gates Part #s for coolant hoses ?
1995 LT-1
Sprung a leak...... Time for new coolant hoses.
Any Gates part numbers please ???
( all of them )
Thanks !
Old Mar 4, 2013 | 10:27 AM
LongBeachC4's Avatar
LongBeachC4
Upper-eng. to pipe; eng vin J 20786 cut to fit; 2 required
Upper; eng vin P 22463
Lower-red tp valve; eng vin J 24022 3 1/2"
Lower; eng vin P 22464
Heater to tank; eng vin P 19743
Tank to eng; eng vin P 19719
Valve to eng; eng vin P 18729
Heater to valve; eng vin P 90 molded 28467
Throttle body eng P 18030
Heater to res; eng vin J 19743
As per Gates
Old Mar 4, 2013 | 11:36 AM
John A. Marker's Avatar
John A. Marker
I just replaced EVERY coolant hose on my 95. The top radiator hose I replaced in October since it blew out on my during autocross. And that hose had been replaced sometime in the past. All the other hoses were original. I replaced the bottom radiator hose about a month later (preventative maintenance). Then three weeks ago I replaced every coolant hose that was left. I bought the standard hoses from Rockauto. Then I replaced the hoses that were attached to the aluminum lines off the coolant fill tank.
A head up.....buy the heater control valve if you are going to replace the hoses to the heater. It is plastic and will probably break when you put it back in. I found one at Autozone...about $10.00.
Old Mar 4, 2013 | 11:38 AM
corvetero's Avatar
corvetero
As per Gates
What about for a LT1 92?
Old Mar 4, 2013 | 11:44 AM
LoneStarV's Avatar
LoneStarV
Don't for get to order some of these Gates thermoplastic clamps as well. Slick as snot and i think Rock Auto carries them.
Old Mar 4, 2013 | 01:22 PM
LongBeachC4
I did this off the Gates web site, so I only looked up this application
Old Mar 4, 2013 | 02:43 PM
Blue95C4's Avatar
Blue95C4
Thanks Guys !! Good tip on the valve!!
To Gates Part #s for coolant hoses ?
