Headlight Motor Wont Stop Running
Old Mar 4, 2013 | 07:39 PM
CSmax's Avatar
CSmax
Default Headlight Motor Wont Stop Running
My 85's headlight motor will not stop running when its in the closed/off position. The motor moves the light housing up and down ok, but once its in the closed position it will not stop running (have to disconnect pwr to the motor).
When I put the car away in November for the winter it worked fine.
The headlight motor was purchased exactly 1 year ago from Corvette America (rebuilt).
Any thoughts?
Thanks..
Old Mar 4, 2013 | 07:44 PM
TBSS/85vette's Avatar
TBSS/85vette
When my '85 did the same thing I ordered a headlight repair gear and after it was installed never had the problem again.
Old Mar 4, 2013 | 07:47 PM
CSmax's Avatar
CSmax
What did you have to do?
Replacing the the whole motor was easy, how do you replace the gears?
Mine is only 1 year old (actually only 4 mos of use)--a gear already?!
Old Mar 4, 2013 | 08:23 PM
randy ransome's Avatar
randy ransome
Winner 2020 C4 of the Year - Unmodified
2018 Corvette of Year
2017 C2 of Year Finalist
2015 C4 of Year
Yea the big white nylon gear inside the motor is stripped.
Order one from one of the vendors on here and remove the motor
take it apart and replace the gear.
Not a hard job just take your time.
Good luck.
Old Mar 4, 2013 | 08:28 PM
TBSS/85vette
It sounds like I had the same thing happen. I was standing in my driveway getting ready to take it on vacation when the motor just took of on it's own. Had to unplug it when it was down. I ordered a repair gear off of ebay. I found a tutorial, I think it was on here,and takes maybe an hour. Take the motor out, open it up, it has a handful of screws that seal it. Replace the gear and reassemble the motor. You will need a good moly grease for inside the motor and RTV to reseal it. It is wise to do both sides at the same time.
Old Mar 4, 2013 | 09:12 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Here's a link to a post by Cliff Harris on the repair..
http://forums.corvetteforum.com/c4-t...placement.html
Old Mar 4, 2013 | 09:57 PM
aklim's Avatar
aklim
I decided to change the bushings AND the gears while I was there. Luckily so. Usually when I shortcut something, it never pays off. Later on, I noticed a hairline crack on one of the gears.
Old Mar 4, 2013 | 10:52 PM
CSmax's Avatar
CSmax
Thanks for the replys..
Like I said just replaced this motor a year ago, why bad already..
If I decide to use/replace the large with brass instead of nylon, is it ok to leave the small gear alone (nylon).
Old Mar 6, 2013 | 09:23 AM
CSmax's Avatar
CSmax
Looks like my motor was part of a bad batch. Out of 40 sold 12 were sent back (now 13) to corvette america in the past year.
Replacement arriving tomorrow--we"ll see..
To Headlight Motor Wont Stop Running
