I just noticed some fresh spots on my garage floor beneath the overdrive fluid pan. I changed the fluid and put in a gasket a couple months ago. How do you fix the leak? It appears to be very minimal. As long as I change my fluid regularly, does it even matter?
I used the gasket from MAD. This may sound stupid, but if RTV is used, will it prevent from being able to remove the O/D pan in the future? Isn't RTV permanent or whatever :crazy:
Re: 4+3 overdrive notorious for leaking? (FlyboyZR1)
Just had the same problem. Pan gasket from MAD = leak! Changed to RTV and fixed problem. IHMO it is a cheap cardboard gasket, and needs to be improved. Pan should not leak with a good gasket installed.
It is generally accepted to NOT use the gasket. It will leak,... GM used RTV. The important part was already stated,..... Clean AND Dry. Any film of ATF will cause a future leak. Make sure you RTV around the bolt holes.
St. Jude Donor '04-'05-'06-'07-'08-'09-'10, '14-'15
"Quote"
ZylaRace Has the right answer!! Do not use the gasket!!
I have an 86 and have never had a leak as long as you follow the Above.
