What is the Flowmaster aluminised finish, does it last?
Old Jun 17, 2002 | 12:05 AM
737driver's Avatar
737driver
Default What is the Flowmaster aluminised finish, does it last?
I'm looking at Corsa stainless steel vs. flowmaster cat back systems. What does the flowmaster aluminized finish consist of? And for those of you who have some miles on you system does it hold up well? I hate to spend the extra money for the Corsa but want something that will last.
Thanks,
Bruce
Old Jun 17, 2002 | 12:22 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: What is the Flowmaster aluminised finish, does it last? (737driver)
I have the TPIS custom FlowMaster cat-back on for over a year with no apparent signs of deterioration.
I don't know if it's aluminized since it has a black external coating.
I believe a SS system would outlast aluminized/painted systems, though not sure by how long.
I selected my cat back for it's high flow characteristics, not longevity. Though I won't be disappointed if it lasts a long time.
Old Jun 17, 2002 | 01:40 AM
Raysur's Avatar
Raysur
If you want the system to last stainless steel is the only way to fly. I'm making my own system with t-304. It's great looking stuff. :cool:
Aluminized steel is alright but these cars should get the best. My car came stock with ss, so ss goes back in. :yesnod:
[Modified by Raysur, 9:43 PM 6/16/2002]
Old Jun 17, 2002 | 01:54 AM
Aggravated4life's Avatar
Aggravated4life
Default Re: What is the Flowmaster aluminised finish, does it last? (Raysur)
I have to say the flowmaster aluminized silver finished mufflers dont appear to last very long when exposed to the elements of year round weather.
You will get alot of rusting around the welds and etc.
In fact,I had a flowmaster set that rusted out and broke at the weld and rear hanger studs so I got new ones again.(great muffler btw,sounds great) and before installing them new,I cleaned the surface really good and put 3 coats of high temp alminum color paint on them to try to resist corrosion.
A year later the rust was coming through.
Its not bad rust but enough to make you cranky,and need to respray the mufflers again under the car with spray paint to help keep them looking nice.Dont expect them to look great after a year or so.
If you have the money,SS is the way to go.
You wont be sorry and the money I spent on 2 sets of mufflers over time couldve got me one set of SS pipes.
Old Jun 17, 2002 | 02:20 AM
HighHopes85's Avatar
HighHopes85
Got an online supplier? If so, I would like the link.
Old Jun 17, 2002 | 02:34 AM
Raysur's Avatar
Raysur
Default Re: What is the Flowmaster aluminised finish, does it last? (HighHopes85)
Here's where I got my mandrel bends:
stainlessworks.net
I got straight tubing from :
tubessales.com
It's coming together nice. Pictures soon. :cheers:
Old Jun 17, 2002 | 05:09 AM
ToniH's Avatar
ToniH
Default Re: What is the Flowmaster aluminised finish, does it last? (Bill's86Coupe)
My advice is that you put some good quality zinc-paint first to the bare metal and then protect it with some heat paint. Zinc paint is great in corrosion resistance but it can't take much mechanical wear and needs protection.
I installed Walker rear Y-pipe and Dynomax Ultra Flow SS'. I got the seams welded and protected the Y-pipe and welds with the paints mentioned above. I have also done this for my other car and have good experiences.
Stainless will easily outlast unprotected (even alumized) steel pipes but SS pipes are much heavier though. With some work you can make the alumized pipes last a very long time.
Greets,
ToniH
[Modified by ToniH, 11:21 AM 6/17/2002]
Old Jun 17, 2002 | 11:14 PM
737driver's Avatar
737driver
Thanks for the info guys. I think I'll bite the bullet and go with the Corsa system.
Bruce
To What is the Flowmaster aluminised finish, does it last?
