How To Change This Bulb ???
Old Mar 7, 2013 | 09:33 AM
Wayne88's Avatar
Wayne88
Default How To Change This Bulb ???
What's the easiest way to change this side marker bulb?
Remove the wheel well?
Remove the tail lights?
From undeneath?
Old Mar 7, 2013 | 10:19 AM
383vett's Avatar
383vett
Have one person hold the bulb and 4 people turn the car. sorry, Reach up underneath, turn the bulb holder counterclockwise and it will come out of the light assembly. Remove the bulb from the socket.
Old Mar 7, 2013 | 11:38 AM
leesvet's Avatar
leesvet
Originally Posted by 383vett;1583300810[I
]Have one person hold the bulb and 4 people turn the car[/I]. sorry, Reach up underneath, turn the bulb holder counterclockwise and it will come out of the light assembly. Remove the bulb from the socket.
he obviously does not have his FSM yet or he'd know that someone had to hold the bulb.
Old Mar 7, 2013 | 11:39 AM
TorchTarga94's Avatar
TorchTarga94
Get under the car and have a look. Really simple.
Old Mar 7, 2013 | 01:25 PM
Wayne88's Avatar
Wayne88
I just tried reaching from underneath, it won't work, the Borla mufflers are too bulky.
I think I'll try taking the wheel well off, probably easier than going thru the tail lights.
Anyway, I have plenty of time, I won't be using it till the weather gets nicer.
Thanks for the input.
Old Mar 7, 2013 | 02:21 PM
pmihaltian's Avatar
pmihaltian
Slingshot
There are just a handfull of Torx bolts that hold the rear inter wheelwell in place. Remove your rear tire & the plastic inter wheelwell and you should have unobstructed access to the side marker light assembly.
Old Mar 7, 2013 | 06:29 PM
fredd1's Avatar
fredd1
If you remove the lower three torx screws from the rear section of the wheel well you can flex the bottom quarter panel out a few inches and access the bulb socket from below. I have borlas on my '84 and have done it, although YMMV.
Old Mar 7, 2013 | 06:58 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Have you tried?
Old Mar 9, 2013 | 07:57 AM
Wayne88's Avatar
Wayne88
Thanks, I’ll either try that or take off the wheel well.
Right now my Vettes are sleeping in my garage and there is snow on the ground.
So this is on my list of things to do when the weather gets a little warmer.
To How To Change This Bulb ???
By Michael S. Palmer | 2026-06-03 11:00:24
