Lt1 NOS on a l98
*The solenoids seems to be better
*The plate that goes onto the TB.
I am thinking about bleeding the valve in after the MAS AF and before the TB
I am kinda nervous about it. I am going to be consirvative and only run a 100 shot.
I am going to upgrade my fuel pump from stock.
I do plan on running 2 10lb tanks into a 4 way with a gauge to monitor the combined pressure of the tanks.
On paper this seems like it wont kill me and should not hur my motor....on paper
Thoughts?
Its a stock l98 (1985) NO Cat
Eliminated the air pump and Ac
dont monkey around with NOS. It will leave you disapointed.
The cars out there winning today are blown. Turbo's / superchargers are beating up on NOS cars in the big leagues.
The issue with NOS is that you make more power on a full tank of NOS than you do a half tank.
So if you tune for full tank of NOS, you will run rich when spraying at a half tank.
Heres the key statement:
Even if you are using a bottle heater to ensure you are spraying at the same PSI, you will still make less power with anything less than a full tnk.
I have heard of new NANO nitrogen assisted pushers, but I dont hve any experience
Skip the NOS and save up for a blowersetup. Talk to grg@blowerworks.
If you dont want to take my advice, then be sure to run a 'wet' setup (sprays raw fuel at the same time asnitrous). I ran an NX wet100 shot for years without incident. Tht same motor is running a blower/meth injectin now.
Itd be a good idea to upgrade fuel pump to walbro 340 255 l/hr pump with racetronix harness.
This becomes must if you evr go above 100 shot.
Good luck.
Good luck.
My DD is a 02 F150 Harley Davidson with the 5.4 SC Motor. It makes just over 650 at teh rear wheels and is pushing 19 psi via the blower. I run an Alky Control Meth injection system on it to ensure octane is always high tto avoid detonation. The M1 mix is 70/30 so my effective street octane under boost is about 107-108. The other advantages of the meth are the colling that occurs at the IAT as well as the nice fresh cleaning it does to the valves. I had my heads off a few weeks ago to up the cams and the valves were baby butt clean with about 10k on them.
NOS is a great seat of the pants hit but one wrong thing and boom goes the block.
