Questions upon Header Wrap..
Old Mar 9, 2013 | 10:05 AM
90TorqueMonster's Avatar
90TorqueMonster
Default Questions upon Header Wrap..
So for the past 6 months Ive had this feeling that I should have wrapped my headders, I hear about how it reduces heat and helps the engine bay.
Has anyone done it?
Does it really make that much of a diiference?
Whats the life span on these wraps?
Old Mar 9, 2013 | 10:27 AM
aboatguy's Avatar
aboatguy
If you have quality COATED headers there's no reason to wrap them on a DD street car.
IMO the cons outway the benefits on a street car.
Your question should be what is the life of a wrapped header on a street car.....
MIke
Old Mar 9, 2013 | 10:31 AM
90TorqueMonster
MIke
Well I can say my hedders seen better days due to a bad valve cover gasket and dipstick problem(leaked on the hedder) so now I got these cute dalmatian hedders
That is a good point I can see wraps being used on the strip, and since my vette is used for the street i assume the life is much shorter,
Thanks!
Old Mar 9, 2013 | 10:41 AM
c4cruiser's Avatar
c4cruiser
I noticed that with my Hedman Elites (coated) the warranty on them will be voided if they are wrapped and then rust through. The wrap can hold moisture and rust will start to form where scratches or other damage would remove the coating.
Old Mar 9, 2013 | 10:51 AM
90TorqueMonster
Wow never heard of thought of that, I too have heddman, but ceramic, I think there great 1 5/8 long tubes, maybe I should keep em the way they are now haha
Old Mar 9, 2013 | 01:24 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
i had a set of coated hookers that i wrapped, you could feel the difference in temperatures under the hood. once i dropped a bolt onto the headers while it was running and just reached down and picked it up with no problems. never drove the car in the rain so the wrap lasted a pretty time.
Old Mar 9, 2013 | 02:10 PM
WW7's Avatar
WW7
I have never wrapped coated headers, but years ago I wrapped painted headers and within 3 years they turned to dust.. They actually disintegrated inside the wrap.I think using them on the street let them get wet a few times and caused this.problem.....Never again...WW
Old Mar 9, 2013 | 02:21 PM
93 ragtop's Avatar
93 ragtop
if you leak oil on headers that are wrapped, it is very likely to catch on fire.
Old Mar 10, 2013 | 09:15 AM
gerardvg's Avatar
gerardvg
Has anyone done it?
It does reduce the engine bay heat, performance wise nothing in it.
It will shorten the header life, depending on how well tuned the engine is the headers will last a 2 to 3 years before they start to leak as the metal gets thin.
This is why i no longer use the heat wrap, see what people say who have used the ceramic coated headers?
Old Mar 10, 2013 | 10:25 AM
PDQUIK95's Avatar
PDQUIK95
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
For a daily driver that sees rain and wet environments, probably not a good idea with steel exhaust pipe even if coated. In my case if interested, I used the wrap on the aluminized steel exhaust pipe from the collectors back to the center muffler but it stays in the garage with minimal exposer to rain. I did this mainly to keep excess heat away from the floorboard and out of the cockpit. It does help and I saw no pipe deterioration over 6 years. I also use it on the ceramic coated headers fwd.of the collector next to the oil pan just to keep add't. exhaust heat from transfering to the oil since the header tubes run so close to the pan.
That's because I have Hard block half fill in the water jackets which will cause oil to run a little hotter anyway due to reduced oil heat transfer with the water jacket side. I don't run an aux.oil cooler and am able to manage oil temp without a problem. How much the wrap helps is hard to say but it can't hurt. I also use the aluminized sticky back thermal tape on the trans cooler lines that run next to the block to help control tranny temp. Just my 2 cents. I'm sure other peoples results will vary, but to each his own.
Rick
Old Mar 11, 2013 | 12:40 PM
RWH1290's Avatar
RWH1290
2016 C4 of Year Finalist
Default What about the Heat Sleeves ????
Has any one tried the Heat Sleeves that fit loose on the headers. I think that would give you air flow to allow moisture out.
Old Mar 11, 2013 | 01:28 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I've seen that, the owner had a hard time putting it out too.
Old Mar 11, 2013 | 05:01 PM
mtwoolford's Avatar
mtwoolford
On a 75 Chevy V8 Monza (remember Motor Trends 1975 Car of the Year?) where the exhaust wraps extremely tight aound the oil pan , I used header wrap with great success, going from you couldn't get your hand anywhere near the exhaust pipe, to being able to briefly touch the pipe without being burned...huge difference. I was aware of the moisture trapping issues....so when I installed the wrap, I soaked each layer of the wrap (used five layers total) throughly in White high temperature ceramic exhaust manifold paint (spray can) which pretty much made them waterproof; it took a lot of paint but came out looking very good.
On my 96 I used the clamp on heat wrap (that allows air flow between the exhaust pipe and the wrap) on my exhaust where it is routed under the fiberglass rear spring; it worked well, but the only draw back is that it does start to look ragged from being blown around from the air passing under the car. But worth the cost and effort.
Old Mar 11, 2013 | 05:47 PM
WW7's Avatar
WW7
If what your worried about is heat in the engine bay, get yourself a Dewitt's high speed fan.. I bought one of these 2 years ago when I put in my 383, it moves about 40% more air then the stock fan.. The air moving that fast through the engine bay drops the temperture significently to where I can put my hand on the motor after an extended drive..Before installing the fan I couldn't touch the engine for an hour after a long drive..Im sure my wire cables and all the plastic pieces will last much longer because of lower temps ...WW
Old Mar 12, 2013 | 04:15 AM
blackozvet's Avatar
blackozvet
its true that it reduces heat under the hood, and its true that it eats the paint of your headers, here are mine after painting and wrapping header wrap on the top part of the header tubes, I have just taken them off after 8 months,
I have used wrap over the years on different things, it doesnt seem to affect stainless headers or chrome plated headers and i imagine they probably wouldnt affect coated headers.
Old Mar 12, 2013 | 02:44 PM
bill mcdonald's Avatar
bill mcdonald
I had mine wrapped, and when I realized what happens when oil hits them, I carried around a bottle of water to dilute possible fire, and put this under the seat.
I removed the hedmans and removed the wrap, the ceramic coating flaked right off.
Old Mar 12, 2013 | 04:41 PM
Crepitus's Avatar
Crepitus
In addition to the above wrap will very significantly increase the operating temp of the header material. Even if it stays bone dry and oil free the headers will be operating in a hotter more harsh environment.
To Questions upon Header Wrap..
