Doing a valve train upgrade..
Old Jun 17, 2002 | 01:44 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Doing a valve train upgrade..
Well, I cancelled my Hotcam order after talking with lcvette (Thanks again for all the help!) .. I have decided to make a little more of an investment, and build a stronger valvetrain.. Just wanted to see what y'all think!
-Comp ProMag 1.6 Rocker arms
-Engine Works Ti Retainers
-Engine Works Hardened Pushrods
-Engine Works Billet Double Roller timing Set
-Engine Works Rocker Studs
-Engine Works Guide Plates
-Engine Works 0.550" Springs with Dampener
-Meziere Electric Water Pump
-and for the cam, I will use the GM Hot Cam
After chatting with lcvette, I think this will make a much stronger valve train.. :)
-Mark
Old Jun 17, 2002 | 02:08 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Doing a valve train upgrade.. (MarkLT1)
Looks like a good combo, though not sure about the springs (I assume they are matched to the cam & 1.6RRs).
You'll need 10deg locks (keepers) with those Ti retainers.
You might consider new valve seals too. Mine were only about $50 from local GM dealer.
Old Jun 17, 2002 | 02:18 PM
scorp508's Avatar
scorp508
:yesnod: Finish it off right.
Old Jun 17, 2002 | 03:19 PM
James94LT1's Avatar
James94LT1
[QUOTE]Well, I cancelled my Hotcam order after talking with lcvette (Thanks again for all the help!) ..
I hear ya! He's helping me with my head/cam package now!
:cheers:
To Doing a valve train upgrade..
