Best built motor combo
My expereince is that with a $4000 budget, you won't see 500hp on a NA 350sbc. You'd need another $2000 minimum I believe (probably more) and then you'll have an engine whose drivability is compromised. An LS engine can get you to 500hp with less radical parts and better drivability, but $4k won't be enough to make it all work in your car.
If you'd settle for 400hp and your current block is good I'd suggest a good set of aftermarket heads (AFR 205's come to mind) milled to bump your cr to 10:1 with a complimentary cam that can make the most of those heads air flow and still have good street manners with a good 750-830cfm carb.
With the LS motors getting all the love the prices for sbc stuff has come down. You'll probably use all of that $4k budget to make it all happen especially if you need to machine your block at all, but you'll be close and should end up around 425hp at the crank which is pretty zippy.
Scour the Internet and find a reputable shop that has expereince in doing what you want. It might be well worth finding a good shop that will look at what you have and make suggestions. If they do a compression and leak down test and those check out and you can answer the above questions you will have a place to start.
You'll find that getting a 400-425hp reliable good driving 350 is relatively easy but will probably go over that $4k budget. Getting to 500hp without a power adder is going to add a fair amount of $ to it as well as make it not that fun to drive on the street and costly to maintain.
If you are at 250hp and you get that critter to 425hp, unless you make it a dedicated track car you will be well pleased. Gearing if a manual, or a stall if an auto can wake it up a bunch also. The Internet is your friend. You do have to wade through some bs, but you'll find that a good set of heads will be your best bet to reach your goals and a cam matched to that and your gears and intended use. Find a shop with lots of customer recommendations and make it clear what your goals, budget and time frame are. Have fun.
What about a used superram an afr head and a say, 10:1 (or a little more) shortblock? that will get you moving just fine and pass the sniffer/inspection. Would be great for autocross too tons of torque.
May go over budget some unless you have a sound shortblock you want to use
Go for street tq instead of a peak hp number and you will be much happier. Not knowing what the cam specs are a bummer as that tells you what your rpm range is and matching your heads, cam, gears and intake is how you come up with a killer combo.
With it still needing tuned it might be tough, but at what rpm is the engine all done? You may start with a good tune and go from there. The 3.73's are a good overall gear. If I was you I'd probably start with finding a good shop, get a good tune so you know what you have, then just possibly find a good set of AFR 195 heads and try that using your existing cam and fuel injection. Unless the cam is way mismatched you might be very surprised and be under your budget to boot. If you are patient you can find some heads with all the valve train used for $1000-$1300. That's where I'd start. Headers and exhaust if you don't already have that. Unless there is a limiting factor I don't know about, you should be in the 350hp range and jumping a 100hp should put a huge smile on your face.
It literally dies at 5,200 it just drops the power off and you feel the stop of acceleration. I have a buddy that's really experienced in motor builds he's going to help me find parts, tear down the motor, and tune it. He's done both efi and carbed motors. The reason why I don't want to keep my efi is the fact that I'd rather not deal with the breaking parts and my engine wiring harness has been damaged by a faulty battery before I'm just waiting for the day it goes out
on me
Answering the question of why the engine is all done at 5200 is the place to start. I'd think you want another 1000 rpm to get the most out of a set of aftermarket heads.
The right cam, heads, exhaust and tune along with making that efi work right should keep you in budget and gain you 75-100 hp.
Good exhaust.
zf6 is good because you can run a bigger cam and not worry about a stall converter.
Hopefully you have flat top pistons in your rebuilt short block.
AFR 195 eliminator heads,64cc chambers,l98 angle plug.
85 is not a roller block so on the cam just a comp cams 292H magnum.
A regular edelbrock performer 2101 for ease of installaion and hood clearance. Performer RPM would be preferred but a lot harder to fit under stock hood.
Holley 750 double pumper for max HP but a 650dp would be more responsive.
A basic 400-450 hp combo
The AFR heads ARE the horspower. There are other good heads out there though.
Good exhaust.
(1) six inch rods
(2) 2.05 inch diameter intake valves; and,
(3) two piece top ring
Thing is cars that vintage get called in "randomly" ie too often
one more reason I was convinced to stop playing with C4s....couldnt go fast as I wanted and not have the hassle.
