Passenger window problem
Old Mar 12, 2013 | 10:07 PM
85_C4's Avatar
85_C4
1st Gear
Default Passenger window problem
So today I changed my passenger window motor because the old one was going up to slow. I tested out the new one if it worked before I installed , so it did work I hooked up everything back together once I finish I tried it and it won't go down or up I can't hear the motor making noise. I open the panels and took out the motor and hit the switch for the window to go down and it doesn't move at all. The drivers side works perfect. Help!!
Old Mar 12, 2013 | 11:12 PM
DinoBob's Avatar
DinoBob
Run 12v directly to the new motor to test it. It doesn't matter that it is new or worked. It does not work now. So test the motor. If 12v direct runs the motor then perhaps you damaged a wire or a connector.
