Horns
Old Mar 13, 2013 | 06:40 PM
C4Mark58's Avatar
C4Mark58
Default Horns
Both of my horns are shot. Would there be any problems using the O'Reillies or AutoZone type replacements or do I need to find OE?
"92 LT1 coupe
Old Mar 15, 2013 | 04:29 PM
jhimer's Avatar
jhimer
Bought replacements at NAPA.
Freeway Blasters.
You will have to remove the old brackets from the horn and replace to the new.
Good Luck,
John
Old Mar 15, 2013 | 08:52 PM
Silver96ce's Avatar
Silver96ce
I bought Freeway Blasters at NAPA and they work well but I had to change the wire connectors. I later learned about replacement horns with the correct connector are available at NAPA. Try this -
http://www.napaonline.com/Catalog/Ca...622_0397237611 . If it doesn't work try typing "gm horns" on the NAPA site (don't select a vehicle), you should come up with the proper horns.
To Horns
