Tools Needed for Head/Cam swap LT1
This is my first major mod to the LT1.
Thanks!
James
-Mark
If you plan on changing the crank gear you will use a jaw type puller on that though. You might want to think about an balancer installer as well.
Misc. items would include a telescope magnet, Assembly lube, degreaser, small parts cleaner, RTV, idian head gasket stuff. Meizier water pump :) Cloyes true double roller timing chain (Only if you go electric WP though)
-Mark
Ok I am chainging to a double roller timing set, I have the miezere already :D So I will be pulling the crank gear. I need 2 pullers? Please explain differnece.
Be sure to replace the crank seal, waterpump drive seal and distributor drive seal while the timing cover is off.
Aquametallic is right, however In your particular situation you will not require the waterpump gear shaft seal, there will be no shaft to seal after removing the waterpump drive gear and you'll need to get the timing chain cover sealed solidly. the waterpump drive gear, once the cam sprocket is removed, look for the waterpump drive gear retainer, its held with 2 torx bolts, T30 if i remember corrrectly, remove them and the retainer bracket, then find a socket which is just a hair smaller then the inside diameter of the bearing journal on the intake side of the lifter valley, slide the socket in and with a short 1"x1"x2" block of wood, tap the waterpump drive gear out of its hole. be sure to protect and openings with clean lint free rags. you have all the seals you need ;) , and for tools, if you do not have a shop manual, shoot me an email i can fax or email some shots of what they look like. the puller can be had from advance or autozone, the hub puller... i believe autozone has one available on their tool rent as mentioned above.
other tools, not necessary but they make things go smoothly, lots of extensions, ratcheting wrenches, and some help!! the best tool is a good friend or skilled helper, the job will be funner, and go smoother. screw drivers of various lengths, tons of plastic bags, label EVERYTHING, EVERY Nut and bolt you remove put it in a bag with a description of where it came from. organization is the key here! other then that, hammer, BIG Hammer for the stubborn obstacles that are sometimes found, but remember to always think it through first and then act, use only controlled movements! and HAVE FUN!! don't get discouraged if it seems like its taking forever, it always does! Good Luck! and enjoy1
Best Regards,
Chris Polanski
I don't have an autozone or advanced auto around here. There is a orielly's. I'm not sure if they have a rental program but I'll check. Are the pullers very expensive to buy? I may just want to get em for future use and friends cars.
Thanks again!
Yes I live in the middle of nowhere pretty much but the LAKE is Awesome
and what sucked me into moving here! Plus there is no crime, the local hillbillies are to lazy to steal! :lol:
Good luck on the cam swap, if you get good at it let me know...after the gears (3.75's) tomorrow I plan on doing the same. I'd even let an experinced person help. :cheers:
Eric
Thanks I'll check them! You'll love the gears. I'll let ya know how it goes, I feel like I should even get a digital camara to show some steps along the way but I'd need a cheapo one, the heads/cam have stole all my money and more! :lol:
