Automatic trasmition issue
Mar 15, 2013 | 10:00 PM
when I move my shift to drive. the trasmission. make clunking noice and the car jump. same when i move to reverse.
what make my automatic trasmission jump that way and make that bad off a clunk noise
Mar 15, 2013 | 10:19 PM
forgot to mention. new trasmission fluid. new tras filter
Mar 15, 2013 | 10:29 PM
I think I know your problem. Your transmission is missing an n. I think the library has some.
Just kidding. I think you may have a bad universal joint.
Mar 16, 2013 | 12:49 AM
That's the way the older 700r4s work. GM upgraded the transmission with an auxiliary valve body in late 1987 to prevent this.
The best way is to shift into N, wait a few seconds, then shift into D or R.
...Or do like I did and replace the old 700r4 with an '89 transmission.
Mar 16, 2013 | 01:17 AM
i think the replace is out of the questión. i think i like better the neutral and wait . option
Mar 16, 2013 | 01:44 PM
Double check the ujoints just to make sure they are ok.
Mar 16, 2013 | 01:52 PM
Start with the U joints. Cheapest fixes first.
God knows I've thunked my share of U joints over the years between my F cars. (haven't done it on the vette...yet)
Mar 16, 2013 | 02:30 PM
I agree with Cliff,there is an excess of pressure build up,on the early 700r4, this cause that bang&jump.The new auxiliary valve body added a new set of accumulator piston to prevent and absorb this pressure,this from 87 with the new 4l60.it's a rough transmission,but i like it .
Mar 16, 2013 | 02:40 PM
Doug Nash and I are on a mission.
Mar 16, 2013 | 03:29 PM
ok here it go.
what is a U join. and where is located. is there more than one U join.
Mar 16, 2013 | 03:54 PM
Ok man, I was making a joke sorry. You have 6 U-joints (universal joints) located at each end of the drive shaft. Transmission to rear end gear. 2 on each axle. Rear end to hub. The gentlemen suggest you check the U-joints first then follow up with the transmission issue.
Mar 16, 2013 | 04:57 PM
ok I just find out what is a u joint how to change it and how to check for damage.
dont know what i do with out Youtube.
Mar 17, 2013 | 06:48 AM
you tube has everything you need about C4,you can find tons of video about C4 maintance
Mar 17, 2013 | 10:49 AM
Check the motor mounts. A broken mount will let the engine and trans shift. Also, you might check and make sure the c-beam bolts are tight. Either of these conditions can cause what you are describing.
Mar 17, 2013 | 04:10 PM
Find someone with some mechanical aptitude to help you out.
Mar 17, 2013 | 08:12 PM
i think i can doit my self thanks
