lt1/vortec heads ?
Old Mar 15, 2013 | 10:28 PM
david frederick's Avatar
david frederick
Default lt1/vortec heads ?
Converted to l98 can do my own mach. work have heads and manifolds is it worth it. tks. Dave Ohio 89' 6spd.
Old Mar 15, 2013 | 10:31 PM
cv67's Avatar
cv67
St. Jude Donor '05
Better bet. This is a real nice performing head
http://www.airflowresearch.com/index...h8gd6ckelvbd35
Old Mar 15, 2013 | 10:39 PM
david frederick
Forgot to mention, old story, more time than money.
Old Mar 15, 2013 | 11:24 PM
cv67's Avatar
cv67
St. Jude Donor '05
GM Vortec heads are reasonable lots of work to convert Ltx heads to an 89 and not worth it. They make about the same power stock.
EQ makes a real nice vortec head also
Old Mar 15, 2013 | 11:29 PM
ch@0s's Avatar
ch@0s
Pick up some L31 heads and a vortec TPI intake and call it done.
Old Mar 15, 2013 | 11:31 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Of the two choices that you listed, the Vortec head would be far easier to install. Mods would include lower intake>head bolt holes drilled in head...old holes plugged/filled, lower intake ceiling porting, tuning and possible shimming of front spring to accommodate more weight.
Power potential would be similar between the two heads.
Old Mar 16, 2013 | 01:24 AM
vetteoz's Avatar
vetteoz
Originally Posted by Tom400CFI
Vortec head would be far easier to install. Mods would include lower intake>..old holes plugged/filled, lower intake ceiling porting,
The Vortec port is too tall for a reg port intake without welding in extra material.
Like ch@os said , you need the special Vortec only TPI base to run Vortec heads
Reg SBC ports on a Vortec head shown below ( aftermarket head with both intake bolt patterns )
Old Mar 16, 2013 | 06:38 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Yeah, I know. But you can fiddle-fart w/it and make it work. CFI-EFI made them work by stacking two intake gaskets, no welding w/his CFI intake. It's wasn't ideal...but it was better than the stock heads. and ir ran great. In fact, I think the CAR, still does. RIP, Jim.
Old Mar 16, 2013 | 08:08 PM
T. Wayne Nelson's Avatar
T. Wayne Nelson
Tom, I have a question, Why do people ask about the vortec heads, from my understanding they do not allow for much lift, and they do not flow that good. Just wondering...
Old Mar 16, 2013 | 09:18 PM
project C4's Avatar
project C4
The only thing that limits the lift on vortec heads is the retainers hitting the valve seals. I believe stock "factory assembled" vortec heads are limited to about .450 lift before the retainer hits the valve seal. I just did a spring swap on a set of new vortec heads.
Comp cams behive srings and there retainer. Lift good to .575 or so after the swap.
To lt1/vortec heads ?
