help
Old Mar 16, 2013 | 06:58 PM
Bruce D's Avatar
Bruce D
6th Gear
Default help
I recently bought a 1989 Corvette. I thought I was getting a good deal at $ 5000. Oh how I was. I drove it home from the dealer and found it was overheating. Took it back they replaced the radiator and top & bottom hoses. Still overheated. So took it to another mechanic he replaced the thermostat,censors, fan motor, water pump, and hoses crom heater core. Tht was 3 trips to him still car overheated. I then took it to a third mechanic he replacdd thr censors again ont the second trip he replaced the ECM computer still radiator fan will not come on. Any ideas on how to get the radiator fan running would be appreciated.
Old Mar 16, 2013 | 07:21 PM
LoneStarV's Avatar
LoneStarV
Did you check the fuse? Fan relay?
Old Mar 16, 2013 | 07:26 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Hopefully you didn't do any damage to the head gaskets.
Old Mar 16, 2013 | 07:28 PM
Bruce D's Avatar
Bruce D
6th Gear
Yes
Old Mar 16, 2013 | 07:54 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
If I was you I would take it back to the dealer you bought it from and tell them to fix it or keep it. I would not be paying anyone else to fix it.
Old Mar 16, 2013 | 08:07 PM
Bruce D's Avatar
Bruce D
6th Gear
I have already made a vew payments on it or I would
Old Mar 16, 2013 | 08:24 PM
LoneStarV's Avatar
LoneStarV
Ok i have my book out i bought on Ebay...thrilled i get to use it already. Have you traced voltages with a meter? See if voltage is getting to the fan? Trace backwards looking for an open. Also fusible link D is in the circuit. It's located inboard to the battery near the firewall. You should be able to trace your way to the correct one with your meter and see if it's open.
Old Mar 16, 2013 | 08:27 PM
Joe C's Avatar
Joe C
Originally Posted by Bruce D
Yes
to what question? with all the stuff you had replaced, i'd find a competent mechanic and not a bunch of parts changers to troubleshoot the cooling system. get a copy of the FSM - i'm sure there's a proper, step by step, procedure somewhere between those red covers.
unfortunately, most of these cars are sold as-is and w/o warranty. it's a buyer beware issue here.
good gawd, with all the crap you've had replaced, why don't you find another idiot mechanic and just have him jack up the frickin' license plate, and slide in another car.
Old Mar 16, 2013 | 08:30 PM
Bruce D's Avatar
Bruce D
6th Gear
I will ask my worthless mechanic if he has done that lol. I am not to mechanically inclined
Old Mar 16, 2013 | 08:35 PM
Bruce D's Avatar
Bruce D
6th Gear
Lol joe I like that
Old Mar 16, 2013 | 09:01 PM
Kmcoldcars's Avatar
Kmcoldcars
What temperature are you calling overheating? The cars are designed to run hotter than other cars. If the car is truly overheating then you need to troubleshoot the cooling system, which includes the fan, according to the manual. One of the temp sensors will supply the temp to the ECM and it will send a signal to turn on the fan. You will need to check all that is happening when the fan is supposed to turn on.
Old Mar 16, 2013 | 09:10 PM
Bruce D's Avatar
Bruce D
6th Gear
Well I dont let it get over 220 before I turn it off. The fan should turn on at 210.
Old Mar 16, 2013 | 09:16 PM
LoneStarV's Avatar
LoneStarV
With ignition in run position. Jumper terminal B on the ALDL connector to ground see if the fan comes on. ECM connector C1 dark green and white wire to ground see if fan comes on. If it runs it's pointing at the ecm. The next test procedure is calling for the use of a Test Lamp. Does anyone know what tool this is referring to?
Old Mar 16, 2013 | 09:22 PM
rrt898's Avatar
rrt898
When I got my 86. The fan didn't come either. It was the fusable link behind the battery. I don't know if all years are the same. I learned alot on the forum but; you will have to do some of the work yourself.
Good Luck with the car....
Old Mar 16, 2013 | 09:30 PM
H P Bushrod
Moderator Emeritus
The fan came on in my '85 when the coolant temp hit 224 degrees. If I'm not mistaken, my '93 does the same thing. It's normal.
Old Mar 16, 2013 | 09:34 PM
Aaron Keating's Avatar
Aaron Keating
Might have an air pocket in the lines. Take the water hose off from the thermostat housing and pour some water coolant mix in there, until coolant begins weeping out of the thermostat housing.
Not sure why the fan isn't kicking on, alot of guys say it won't turn on till 220. I am pretty sure mine kicks in at 200 something. Because assuming the car doesn't have a large airbubble in the system, mine never gets above 210 in the summer months. (and I live in NC. Not uncommon for us to hit 100+)
Old Mar 16, 2013 | 10:12 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
fans don't turn on at 210. 210 is barely warm for a C4
Old Mar 16, 2013 | 10:42 PM
DinoBob's Avatar
DinoBob
You got a lot of free parts if you think 220 is overheating. C4s run hot. I think the fan comes on at 228.
To help
