Will the real LT engine please stand up
Just run the LT1 as a standalone setup like guys do when they put a LT1 into a non C4
See
http://vetteworksonline.net/LT1%20conversion.htm
Is easier if you use a custom aftermarket bare bones wiring harness without out all the un-needed stock wiring
Only need a 12V supply and a 12V switched (Ign ) connection to the PCM
Would need a LT1 manual tune in the LT1 PCM and one of the many popular means of locking the convertor installed in your car.
Gauges / speedo would still run as they are now ; independent of the new PCM
for use on 1992-96 LT1 engines.
and P/N 12550097 hub for use on 1996-97 LT1 engines.
Did you ever go to the LT1 vs LT4 link posted in one of the threads earlier, some of the P/Ns are there?
LINK
IMO finding the engine parts are going to be easy, IDK about getting through Kalifornia's CARB process. Anyone know what it takes to get a older C4 through carb with a 1996 engine? Does it need to be OBDII or should/can he make it a 95 and use OBDI which is easier to tune in the C4 since its not a 1 year only setup?
Or does Kali let the car go by the model year in which case how's it make it through visual?
Mike[/QUOTE
Good evening Mike , You are Tree Top Tall in my book
.. your very appreciated here ... Yes .. I have read and re checked the part Numbers .. very cool ... Im excited to be here .. thanks for your help !Where are you located exactly .. would love to buy you a smoothie of your choice ....
Im on it !
