700R4 rebuild or replace
Old Mar 18, 2013 | 12:27 PM
vetteaholic24's Avatar
vetteaholic24
Default 700R4 rebuild or replace
long story short ive got an 87 vette with the 700r4 auto trans
local auto trans shop quoted me at $1200-$1900 for full rebuild but i can buy a brand new 700r4 from wholesaletransmissiondistributor.com for $899.00 plus shipping and ive found used with a fresh rebuild for as low as $300
what gives and what would be the best option for a drivers car that might hit the drag strip for fun
btw i can do an install myself just dont have time for a rebuild
Old Mar 18, 2013 | 01:01 PM
ejscarfo's Avatar
ejscarfo
I think you answered your own question. If you can install it yourself, get a new or used one or a rebuilt one shipped to you. I'm sure the labor of removing the tranny from your car is built into that quote from the local guy so you're basically saving the labor costs.
If you're getting the rebuilt one, find out how they rebuild it. Is it all new inside or do they just replace what is broken? If you plan on taking it to the strip, see if they can customize your order with better clutch packs, etc. Also, find out about core charges and the shipping costs for the core. That $300 might triple once you factor in the shipping costs, etc.
When I had my 700R4 done, it was rebuilt all heavy duty and it was warrantied. The rebuild with a new torque converter and flywheel cost me $1300 seven years ago so your quote isn't that bad.
Old Mar 18, 2013 | 03:41 PM
aklim's Avatar
aklim
www.rosslertrans.com for a trans. They can build you what you need and well. They want your trans since they think it fits better or something but that isn't a biggie.
Old Mar 18, 2013 | 05:49 PM
TTOP350's Avatar
TTOP350
Call Dana, he is truely one of the best I've ever delt with.
http://www.700r4l60e.com/
You don't want anything to do with a "stock" rebuild, esp for $300.
Old Mar 18, 2013 | 09:54 PM
HAD2HAV2's Avatar
HAD2HAV2
I just pulled the 700R4 from my 88. Repair shop had it for 6 working days. I took my 700R4 to a local Trans. shop. spent $800 on converter, shift kit, and upgrades to a 4L60E on my 700R4 plus $500 on labor.
Took 2.5 hours to come out and same to go back in. I have 4 post lift and a trans. jack that goes to 6 feet. No problems removing. The install had 2 problems, getting the dip stick tube to line up with the upper housing bolt, and the other was getting the trans. fluid to and from cooler lines back in because both were used to flush out the system and got moved around a bit.
The Trans. support that connects the automatic trans. tail shaft to the differential is not much fun either. Clean this support after removal and grease it around the bolt holes so you can move it about. I only need to connect the flywheel to converter bolts.
Looking forward to flooring it this coming weekend.
Old Mar 18, 2013 | 11:03 PM
aklim's Avatar
aklim
I generally find the cheapest price for a trans like Jasper and know that I have to pay way more than that. For a good built trans, you are going to look in the $2000 region if you want to use good new parts. If you are not picky about whether it is a rebuilt converter or not, sure. Looking at a Vigilante TC, it is about $800 so if they are giving you a fresh rebuild, you can bet it won't have that TC from wholsealetransmission. Probably some stock rebuild at best. If not, well........
To 700R4 rebuild or replace
