Rear Differentail Fluid Change Questions
Old Mar 19, 2013 | 08:52 PM
KJL's Avatar
KJL
Default Rear Differentail Fluid Change Questions
I actually did this a few years ago to my 96 and now want to to do it for my 95 ZR1. Funny thing is I forgot how I did it. What side is the plug on? What size is hex wrench does it take? What is best way to access plug? If I recall I had the car up on ramps and jacked the rear of the car up and placed on stands. If I recall if was a real pain to get to.
I have a vacuum pump and all the tools at least.
Old Mar 19, 2013 | 09:10 PM
LT4 F45's Avatar
LT4 F45
It is on the passenger side and not that bad to get to...
Old Mar 19, 2013 | 09:35 PM
Glenno's Avatar
Glenno
What is the correct limit slip fluid to use? Brand, weight, additives, etc?
Old Mar 19, 2013 | 09:46 PM
WVZR-1's Avatar
WVZR-1
That debate happens pretty frequently and is a "personal choice"!
FSM specifies I believe 80W-90 GL5 and GM additive. Lubricants have improved through the years and you can consider the FSM as I guess a "minimum" spec. The debate can be likely a couple pages. I've always used the GM fluids. Habit!
The original I still have is 1052271 and 1052358 for additive. Both I believe have recently changed part numbers.
KJL - you asked fill plug size - 3/8 hex I believe if original. You asked how? It will all come back to you!
Old Mar 19, 2013 | 09:47 PM
Glenno's Avatar
Glenno
KJL - you asked fill plug size - 3/8 hex I believe.
Thanks for the info.
Old Mar 19, 2013 | 10:02 PM
Kevin Woods's Avatar
Kevin Woods
That debate happens pretty frequently and is a "personal choice"........I've always used the GM fluids........
Yep.....matter of personal choice......and I also use the GM fluid .
Takes all the 'guesswork' out of the equation .
KW
Old Mar 19, 2013 | 11:47 PM
383vett's Avatar
383vett
The size for mine was one big vicegrip.
Old Mar 20, 2013 | 06:22 AM
Glenno's Avatar
Glenno
KW
Does the GM type fluid come with the slip additive already in it or do you purchase two products and mix them? Thanks
Old Mar 20, 2013 | 06:53 AM
WVZR-1's Avatar
WVZR-1
Use the part #'s in my post -- additive is a seperate purchase (*you need just 1)
*people mention using 2 if they have problems - I don't know that actually helps.
Old Mar 20, 2013 | 07:26 AM
ex-x-fire's Avatar
ex-x-fire
Get yourself a long 3/8 wrench & a 3/8 allen wrench, cut the allen wrench to make a bit about 1.5" long. The have the bit welded to the 3/8 wrench.
Old Mar 20, 2013 | 07:48 AM
KJL's Avatar
KJL
Thanks for the feed back, I believe I have an allen 3/8" socket already, I guess I will need to remove the passenger side rear wheel and jack the car up access.
Old Mar 20, 2013 | 02:23 PM
KJL's Avatar
KJL
I have Mobil 1 75W90 Synthetic, will this work? I think I read in a thread that this was ok to use.
Old Mar 20, 2013 | 04:14 PM
LT4 F45's Avatar
LT4 F45
I use Amsoil 75W90 no additive
Work great but right after the change i had to make 8's figure in a empty parking lot to get the fluid to the clutch in the diff...
Old Mar 20, 2013 | 04:50 PM
DAVECAD2.0's Avatar
DAVECAD2.0
Or, or, you could just buy one. They come in long and short hex lenghts. About $10.00 for a cheapo and about $25.00 for Snap-On.
MTCW
Old Mar 20, 2013 | 04:59 PM
dizwiz24's Avatar
dizwiz24
Someone once recommended eith lucas 75w-90 or 75w-140
No additive reqd. I use 75w-90.
To Rear Differentail Fluid Change Questions
