Cold Start FI
Old Mar 19, 2013 | 08:59 PM
shamdave's Avatar
shamdave
Default Cold Start FI
I am planning on upgrading my FI this week I am going to eliminate the CD FI. Can i plug off that part of the fuel rail with a cap? if so what size and where can i get it?
This injector thing looks like a certified pain in the **** to i only want to do this once.
all help is appreciated
Old Mar 20, 2013 | 08:47 AM
vetteoz's Avatar
vetteoz
Is usual to remove the fitting altogether and plug the hole in the end of the fuel rail
http://www.hawksthirdgenparts.com/pr...elete-Kit.html
What are you doing about cold start fueling with the injector gone?
Old Mar 20, 2013 | 10:41 PM
shamdave's Avatar
shamdave
I am buying the Bosh III per John I can safely remove this
BTW thanks for the info
Old Mar 25, 2013 | 01:36 PM
tunedport85inject's Avatar
tunedport85inject
probably he means what is your strategy for cold start engine since without the 9th injectors you have a rough hard start.Do you upgrade 165 ECM and arap.bin 89? Since 89 the cold start was deleted and start up enrichment was changed in the bin. to add more fuel during start up if coolant temp is < than...
Old Apr 23, 2013 | 05:26 PM
Joe Gibson's Avatar
Joe Gibson
8th Gear
I did these mods on my 86 Convertible, here's what you need to do....
- remove the fuel line from the fuel rail to the 9th inj.
- plug the fuel line hole in the fuel rail
- plug the injector hole
*if using the round plug with no bolt place it in a freezer for several hours then run it out and insert it into the inj hole and hammer it in with the beveled side down while it's still as cold as possible. the medal will expand as it warms and will seal the hole.
- install the new injectors
* while you have the top half of the engine scraped off tighten all the bolts for the air intake manifold per the manual also a good time to replace the EGR valve and fuel pressure regulator.
- Contact PCMForLess.com to get a custom built performance chip for your car, I think it's like $100 have them delete the 9th injector.
Call it done, on mine when the car has been sitting over night the first start up will sputter at 400 RPMs I just give it a tap on the gas and it's happy from there on and warms up at 1200 RPMs before dropping back to 800 RPMs.
These mode made crazy performance changes for my car and well worth the money/time
To Cold Start FI
