Iridium Spark Plugs
Old Mar 20, 2013 | 08:16 PM
Klyde's Avatar
Klyde
Default Iridium Spark Plugs
I ordered and recieved a set of NGK ITR5F13 spark plugs for my 1996 LT-1. They are nicely constructed but none of them came with any compression rings. It's been awhile since I replaced plugs. Is this how they are now. Do you order them seperately or do you not use them at all?
Old Mar 20, 2013 | 08:30 PM
dsandmire's Avatar
dsandmire
Is there a difference between aluminum heads Vs steel--think one uses comp. rings, the other doesn't. Getting old is terrible.....
Old Mar 20, 2013 | 08:35 PM
Klyde's Avatar
Klyde
Yes. Technology moves on and if you don't do something often (like change plugs every 50,000 miles) then sometimes things change and you don't know it. The plug does have a tapered edge at the seat and it is possible that it doesn't require a compression ring. I just don't want to mess up when it comes to aluminium heads.
Old Mar 20, 2013 | 10:53 PM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
Pull one of your old spark plugs if they have tapered seats then that's most likely what you should use.
Old Mar 21, 2013 | 11:24 AM
LannyL81's Avatar
LannyL81
Have not seen compression rings for many years....all now use tapered threads. Gap those plugs and put them in. I put these in both my '95 and '96...nice throttle response....well worth the cost and trouble to install.
Just be sure to use anti-seiz on the threads.
Old Mar 21, 2013 | 06:08 PM
Klyde's Avatar
Klyde
Ok so I'm showing my age Thanks for the feedback. NGK recommends 50 gap is that what you use or something different?
Old Mar 21, 2013 | 07:08 PM
bogus's Avatar
bogus
They should be pregapped to .050...
Be VERY careful gapping iridium plugs. You can hurt them if you aren't careful. Use a pair of pliers to pull the gap wider, press down on the strap to close the gap. Do not put any pressure on the tip of the electrode. It will hate you for it.
To Iridium Spark Plugs
