True Duals or Single Cat
Old Mar 22, 2013 | 10:21 PM
Deepa's Avatar
Deepa
Default True Duals or Single Cat
All,
Trying to decide on what to do. 91 L98 with TPIS long tubes, TPIS Y-pipe, and Corsa Cat-back. My cat is shot (mangaflow aftermarket, honeycomb exploded when my pick up coil died and the unburnt fuel blew the f--- out of it.)
So first off, I need emissions. The car failed with the busted cat, but that was with the 350 motor and now a 383 is going in.
I think true dual exhaust is cool, esp with corsas on the back, but it makes the rear y-pipe useless (so what...) I would have a performance exhaust shop (fantastic) mate up my long tubes to the mufflers with two cats inbetween. This would be the last step and it would be removable somehow. Maybe a clamp at the header and one at the back end of the cat?
The other option is to get another magnaflow for an early TPI (4 bolt flat flange on the front to match my TPIS Y-pipe with the same fitting) and bolt it all together myself.
I don't mind paying a shop for mount it all up as I can do the headers without a problem.
Another issue is the cost of cats if i went true duals. My old magnaflow cost like 120 shipped to my door. Two cats to get welded in would be more expensive. If i go true duals, what cats?
Thanks,
Mike
Old Mar 23, 2013 | 12:52 AM
leesvet's Avatar
leesvet
ANY late model cats can be welded in for true duals and a solid welded in system and leave 'em.
There is absolutely zero reason to take cats out and go thru all that silly sht pullin 'em and puttin 'em back...they do not harm anything, so whats the point? new cats are so free flowing you cannot even measure any back pressure thru them. Old stories 20 yrs ago...sure, pull em first chance. Now, no reason to do that.
I'd go duals, 2 cats welded in, weld in the entire system to the back and forget it. IF anything gets bolted...flange the mufflers so they can be dropped and a muff eliminator stuck in for race day. Corsa makes a good eliminator, 1 inlet 2 real exits.
Old Mar 23, 2013 | 09:12 AM
Deepa's Avatar
Deepa
Lees, Always appreciate your input. I thought it would be easier to service with the headers being able to be unbolted and maybe another clamp at the muffler? That way in case I had to remove the exhaust for various repairs it would be doable?
What cats dol you recommend? My TPIS long tubes are 3" at the collectors.
Thanks,
Mike
Old Mar 23, 2013 | 10:43 AM
leesvet's Avatar
leesvet
Mike, flanged at the collector is fine, for the reasons that you specify. I'd weld from there back...to the far end where IF you wanted that bump from no mufflers, I could unbolt the muffs and stick an eliminator pipe in its place...I guess if hung properly you could actually bolt the entire system together...
I like welds...and I have a sawsall
cats? they are all pretty much free flowing these days. There are some that are better than others of course...but at what $$$ ? thats the issue. They range from $125 to $350ea and some are limited to what state you are in..what will FIT will ultimately decide this.
I'd buy a brand name or something from a reputable seller, chain store or trusted online source. I just have not heard of any disappointments in the cat supply in the last few yrs since the technology seems to be thru the entire industry. With true duals...there is less gas trying to pass so the build up of back pressure is greatly reduced. Trying to stuff 8 cyl worth of gas thru a similar size pipe might create a mild build up...but likely not enough to choke the engine down.
Old Mar 23, 2013 | 10:56 AM
bogus's Avatar
bogus
A tip about cats... California has mandated that replacement cats must meet OBDII standards for durability.
The problem? They cost more upfront. The advantage? They last so much longer that they pay for themselves in no time flat.
I am with Leesvet on this. Do a dual system with bullet cats and be done with it. You will pick up real power with this setup, too. 20hp, or so. That's how restrictive the OEM single cat system is.
Old Mar 23, 2013 | 03:53 PM
Deepa's Avatar
Deepa
I wont need muffler deletes as i enjoy hearing lol.
I'll go with the duals...should i be looking for 3" cats?
Mike
Old Mar 23, 2013 | 04:07 PM
LoneStarV's Avatar
LoneStarV
I've done a lot of research and made some phone calls including TPIS and Random Technology. Unless you're running a monster cube engine you don't need duals i don't care what anyone tells you. Your TPIS LTH with the TPIS y pipe into a Random Technology main cat will work great. Call TPIS....call Random Technology. In fact you have the EXACT same exhaust set up i'm going to change to. You can unbolt and drop all of it any time you need to. Why weld it?
Old Mar 23, 2013 | 04:56 PM
LD85's Avatar
LD85
I love my Pypes true duals, everything fit perectly
http://forums.corvetteforum.com/c4-t...s-reviews.html
Old Mar 23, 2013 | 05:17 PM
LoneStarV's Avatar
LoneStarV
Come now Larry. You're also running a space shuttle engine in your vette with a 55 gallon drum bad azz custom intake we're all jealous of...lol
Old Mar 23, 2013 | 05:43 PM
LD85's Avatar
LD85
I'll never tell,, but I would say that true duals WITH CATS might make sense.
I had the cats and they seemed to work well but they really got hot due to the unburned fuel in the exhaust on my car, hence my cam swap
Old Mar 23, 2013 | 09:57 PM
aklim's Avatar
aklim
That is my setup. I wouldn't weld it because I want to be able to drop it when I want. Past the cats, I have Borla Stingers.
Old Mar 23, 2013 | 10:24 PM
l98tpi's Avatar
l98tpi
Max G’s
with true duals, unless you place an x-pipe close to the headers, you will loose the exhaust scavaging and sacrifice some power. I tried true duals several years ago and lost power and quick engine spool up. Went back to y pipe up front then into single then y at the rear.
Old Mar 24, 2013 | 01:06 AM
bogus's Avatar
bogus
Mike
no way... if you go with duals, 2.5" is more then enough on an otherwise stock car.
Old Mar 24, 2013 | 09:27 AM
TA's Avatar
TA
This is what I'd be buying if I hadn't already done my exhaust
Old Mar 24, 2013 | 11:40 AM
aklim's Avatar
aklim
Even if you do X pipes close to the headers, will you get enough to justify the effort? Like Lonestar and I did, buy TPIS long tube headers, Y pipe, Random Tech cat and say a commercially available 3 inch exhaust, will we gain much going to an X-pipe setup?
Old Mar 25, 2013 | 01:11 AM
aklim's Avatar
aklim
If the car is going to be stuck at stock, why the hassle?
To True Duals or Single Cat
